S1r PDF coil description and discussion !!!!
Started by xbox hacker, July 08, 2008, 03:20:41 PM
happyvalley808
@Cap70,
I will send a link in a few minutes for GEET build diagram... it is designed to run on a small motor,lawn mower..
Regards,
HV
happyvalley808
@Cap70,
Here it is .....Paul Pantone's "GEET" plasma fuel reformer....I will be building one within the next week or so, I have studied this system, so if I can help let me know.....
Regards,
HV
xbox hacker
capacitor70
Today I build DC to DC converter Its output voltage can be controlled from 100V to 600V, using TL494 and emergency lamp transformer, I am having problem to
run using 330uF 400V capacitor when I connect this it starts heating transformer and MOSFET (due to low rating of Xmer), it gives good plasma blast with 330uF at first time but after some time it burned transformer primary and TL494, Again I assembled all to see whats the problem keeping bulb in series with circuit to monitor current, and found that after first blast TL494 makes duty cycle to 90% because of this it dosen't work after first blast, But circuit is good for low value capacitor 10uF 400V.
Below circuit is nice just adjust capacitor and resistor to high frequency and make ferrite core transformer, only problem of this circuit is it is unregulated output voltage. No heating of mosfet and xmer. go with this circuit. for real application, I used this circuit on my bike for one day no problem at all. with plasma spark power boost is observed...
