Infinity Coil
Started by z.monkey, July 11, 2008, 08:12:41 PM
z.monkey
Goodwill to All, for All is One!
z.monkey
Eight Cores!  Don't need no mo...
I am glad this thing is wound.  That was tedious.
Moving on the connecting the wires...
Blessed Be Brothers...
Drannom
http://www.overunity.com/index.php?action=dlattach;topic=5144.0;attach=24735;image
Hi Z.monkey
when i look to your original desing in your first post in this topic, i notice that all coils are in circle, when i look to your replication i see your coils not really in the same circle
if you attempt to create an etheric vortex or a string wave it must be in circle from my point of view
from my point of view the energy will come from the central sun, as any atoms of matter, all is power by the central sun
so if you fail do not panic just try in circle then
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
z.monkey
Howdy Drannom,
The device does work in a loop.  It is a magnetic loop and not an electrical loop.  The original schematic I posted was an electrical schematic.  The forces that we are manipulating are magnetic.  Magnetism works at a right angle to electron force.  So, the cores are aligned to cause the magnetic force to work in a loop, and spin.  And spin it does.  That is the reason this device works.  There is an electromagnetic spinning effect happening within the core.  This EM spinning creates a vortex on either end of the center core.  This vortex pumps energy from the environment through the device.  The Infinity Transformer is fueled by a source that is universally available and totally intangible.  This source is Soft Particles, a quantum form of fuel.  I am not claiming that the Infinity Transformer is an OverUnity Device.  It is a device which utilizes a naturally occurring energy, which is supplied by the sun, which is universally available, yet totally intangible.
Blessed Be Brother...
Drannom
so each core inducing in the next one, ok, i stay on my mind for the perfect circle , then the interaction will be other than inducing ? it was my feeling
That is what i was talking about concerning Central Sun (black hole and super light)!
there is other link on that
http://blog.hasslberger.com/2007/11/milewski_describes_magnetoelec.html
Quote......
SuperLight is described as the opposite and complementary phase to ordinary light. While electromagnetic radiation - visible light is part of its spectrum - has a strong electric and a weaker magnetic component, in magneto-electric radiation the magnetic component outweighs its electric counterpart.
Milewski proposes a model which sees magneto-electric radiation as the source of gravity, emitted by black holes and traveling at the square of the speed of light. SuperLight has a correspondingly shorter wavelength and higher energy content than ordinary light and is the source of the energy of life, which makes for its connection to the area of healing through increased coherence in organisms.
While physics has tended to exclude life and consciousness from its equations we now have - with Milewski's model - a very real possibility to reach unification with meta-physics, generally considered the purview of faith and religion.
Now, I believe a similar event occurs in the extremely dense and hot matter found in black holes. It is theorized that black holes contain magnetic monopoles and when these extremely dense, extremely small, extremely energetic magnetic monopoles release energy by lowering their orbit they radiate magneto?electric radiation, our SuperLight. So black holes really are not so black. They are radiant beings of SuperLight. Of course SuperLight escapes the strong gravitation forces of the black holes because its velocity is the square of the velocity of light and it therefore, can easily escape.
The current scientific thinking is that in the center of every galaxy in the universe is a black hole. There are billions and billions of galaxies all around us, and they all are producing SuperLight. We are literally bathed in a three-dimensional dynamic energy field, or an "Ether" of SuperLight ? a Dynamic Ether.
and much more at the link
there is electrinium.pdf (find at freeenergy.com) a very simple and complete information on the Central Sun
