Infinity Coil
Started by z.monkey, July 11, 2008, 08:12:41 PM
z.monkey
Howdy Wattsup,
I measured the resistance of a 8 primaries in series, which was 2.5 ohms.  Keep in mind that the primaries are 20 gauge stranded wire.  So that is around 0.4 ohms each.  I need to measure each coil individually so that I can document the tolerance, resistance, inductance and Q.  I have a crude Gauss meter which I use to feel the magnetic field.  The Gauss meter is me holding a magnet.  I send a low frequency wave into the coil and feel around the cores, holding the magnet in my hand, to determine the limits of the magnetic field.  As the voltage goes up the field definitely gets larger.  I have several compasses also.
I am not seeing favorable results with the eight primary coils hooked up in series.  So, the next test that I had planned on performing is EMDevices Cook Transformer setup.  See the Hubbard Coil thread for details.  Then we are going to look at alternate arrangements.  Looking at Tesla's work is not a bad idea.  Hubbard lived in the time when both Tesla and Moray did.  I have grown great respect for all three.  There are many factors to this device, so testing every possible configuration could be a time intensive and costly endeavor.  I had hoped to limit the time and expense by building a durable core that is reconfigurable.  This way when one theory doesn't pan out we can relatively painlessly reconfigure the device to try another arrangement.
A note on driving the coils.  I have built a fixed frequency generator to stimulate the coil.  What I lack is the flexibility for testing.  I have to replace caps on a board, and readjust two potentiometers.  I plan on adding a multiposition switch for switching in different caps for the band adjustment.  Then I want to get a 20 turn stereo potentiometer to do the fine frequency adjustment.  So, in essence, I am building an adjustable frequency generator for testing this coil.  Oh, sure, I could just go buy one, but where is the fun in that?
Blessed Be Brothers...
Goodwill to All, for All is One!
z.monkey
Howdy Y'all,
I have been looking at this schematic for quite a while.  At first I had discounted it, thinking there was no designer name and date.  Anyone could have made this drawing and it doesn't jive with my conception of the device.  But, then there was that nagging feeling that there is something that I am overlooking here.  Just one of them things, ya know...  So while I have the coil in a series configuration I am going to try this before I proceed with the EMDevices version of the wiring plan for the Hubbard Coil.  I have a DC to AC driver board already setup to run at 400 Hertz.  I also have a power rectifier board setup for AC to DC conversion.  So I should be able to replicate the schematic on the test bench, albeit with out the step up and step down transformers.  So I will be directly driving the center coil.  Then rectifying the output of the eight peripheral coils to recharge the driver circuit battery and a load.
So were off on a tangent...
4Tesla
Definitely worth trying since you already have it setup!
Jason
guruji
Broli you misunderstod what I had sad.I did not tell him that he wasted the time.
I meant that it was a pity for all that time with little results.
Yes even me I don't want to get in to much ping pong conversation for bullsh..t.
Ok ok have a nice day
Bye.
kinesisfilms
it seems you have your transformers backwards.
