this pyramid should produce electricity. (thomas trawoger's pyramid explaned.)
Started by nitinnun, July 16, 2008, 04:57:47 AM
4Tesla
Quote from: nitinnun on August 02, 2008, 07:05:16 AM
i made another shocking yet basic discovery.
look at the letter "A" on your keyboard.
the letter A, looks like a pyramid.
the line through the middle, electrically sepperates the peak from the base!
the person who invented the letter A thousands of years ago, knew that the pyramids peak must be electrically sepperate from the pyramids base!
they knew how to harvest electricity from a pyramid!
Great Observation!
Cap-Z-ro
I concur.
With all the obvious negative symbolism all around us, what better place to hide the truth than among the weeds.
Regards...
Koen1
@Nittinun: So, have you actually measured any output yet?
If so, what was the voltage?
Is is only static charge on a cap, or do you actually get some current out?
If it's only static charge, does the cap self-charge faster than a normal cap would?
Or is it really just the two different metals?
Perhaps it's worthwile using plastic as the isolator, as other "dielectrics" like
paper can give misleading readings? (Old "dry" batteries often used paper
as "dry electrolyte" since even a small amount of moisture in it, like that
from the air, can produce galvanic reactions.)
Oh, and why do you feel the need to post obvious facts, like the fact that
the pyramid has a strong and near holy connotation for Illuminati, or the
obvious fact that the letter A is a variation on the triangle?
I quite like your approach to the pyramid although it is not very new,
but I don't think you should throw in so much Illuminati nonsense and such. ;)
nitinnun
it is "obvious", that the pyramid on the back of the one dollar bill, has a peak which is electrically sepperated from its base?
and that the all seeing eye inside that peak, might as well be a peak antennae, which is harvesting positively charged magnetism?
it is obvious that THE LETTER "A" ITSELF, has a peak which is electrically sepperated from its base?
and that the electrical sepperation in both of these, is a huge missing link in the pyramid riddle?
the above is obvious, even though i see next to nobody electrically sepperating their peaks from their bases?
let alone make their peaks copper, their bases aluminum, and sepperating peak from base with insulation?
or saying anything what so ever about the above?
either you have a very screwed up concept of what "obvious" is,
or you are passive aggressively trying to argue with me, despite having no ground to stand on, or anything to contribute,
or you are typing, without having any idea what you are saying.
possibly all 3.
