this pyramid should produce electricity. (thomas trawoger's pyramid explaned.)
Started by nitinnun, July 16, 2008, 04:57:47 AM
Koen1
Quote from: nitinnun on August 05, 2008, 05:14:22 PM
it is "obvious", that the pyramid on the back of the one dollar bill, has a peak which is electrically sepperated from its base?
and that the all seeing eye inside that peak, might as well be a peak antennae, which is harvesting positively charged magnetism?
No, that's not what I said. Read what I wrote, don't reply to things I did not say.
Quoteit is obvious that THE LETTER "A" ITSELF, has a peak which is electrically sepperated from its base?
and that the electrical sepperation in both of these, is a huge missing link in the pyramid riddle?
the above is obvious, even though i see next to nobody electrically sepperating their peaks from their bases?
let alone make their peaks copper, their bases aluminum, and sepperating peak from base with insulation?
Well you've clearly not looked hard enough. There's people who have shown pictures of pyramids with a copper top
and an aluminium base and which they refer to as "over unity capacitors" or "pyramid capacitors" out there on the net.
Can't recall a url now, but I've seen several. And yes they claim the thing puts out DC, low amps but ok voltage.
As far as I can figure what you describe is a version of what some have already built.
Nevertheless, I asked why you feel the need to post obvious things, and indeed, the fact that the letter A
is a triangle with a horizontal "seperating" line in the middle is obvious, yes. The fact that the Illuminati
have been fascinated with pyramids, and that the pramid and the rays of light coming from the eye of Ra
as depicted on the Illuminati-designed dollar bill represent a radiance of power from the divine "all-seeing eye"
is also quite obvious for anyone who has actually studied this or thought about it in depth. The "reason for
the angles being 52 degrees" is also obvious, but more from a geometric standpoint, which you have in fact
incorporated into your "explanation" but is more logical than you seem to think.
A fact which is not obvious, however, is one that you keep bringing up, which is the alleged "magnetic field
of the pyramid". Where do you get the idea that a shape has a magnetic field, and that a pyramid would have one
as you drew it?
Quoteeither you have a very screwed up concept of what "obvious" is,
or you are passive aggressively trying to argue with me, despite having no ground to stand on, or anything to contribute,
or you are typing, without having any idea what you are saying.
Haha...
Or possibly the pot shouldn't call the kettle black ;D
Alright, since you seem to have trouble follwing my reasoning, I'll explain.
I asked why you feel the need to point out obvious things, and certainly some of the things you pointed
put in your "theory" are very obvious and not really breakthrough insights at all. Such as the A and the
angles of the pyramids etc. The fact that copper an aluminium have different emission potentials etc and
therefore aluminium charges negatively in respect to copper is a well known fact, not a groundbreaking
realisation on your part. The fact that you need to keep capacitor plates electrically seperated from a ground
or from the oppositely charged plate is also well known. The fact that the A is a triangle is true, but if you knew
anything about the evolution of the alphabet you'd also know that the Aleph, or Alpha, was one of the
very first letters and was originally written upside down witg the horizontal line sticking out on both sides, and
was a symbolic depiction of the cow, which was called Aleph in ancient times in several cultures.
So the A did not start out as a pyramid, it started out as the stylised depiction of a cows head. Sorry.
Furthermore I am not trying to argue with you as there is hardly anything to argue about... You present your
idea of how to build a pyramid capacitor-antenna device that you feel should charge a capacitor fast enough
to produce actual usable output energy. Well, to be honest, I quite like that idea.
I just wonder why you don't just describe your idea, why instead you feel the need to drag things like the letter A
in there for example, and why you act like it's a huge discovery that the sides of the Great Pyramid are at 45
degrees to eachother...
And most of all I wonder if you have by now built and tested your pyramid idea, and if you managed to get output
from it, and how much that output was.
Drannom
Quote from: Drannom on July 20, 2008, 07:52:41 PM
in fact this is 42 degree exactly not 45
look my shema here http://www.overunity.com/index.php/topic,3701.0.html
Koen1, it's always a pity to have to read you, i suggest to everyone to just forget about your silly lost of time, why are you harrassing again someone somewhere, it's an habit ? sure it is.....
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
helmut
Quote from: sevich on August 06, 2008, 07:46:14 AM
The fact is that Iluminati, Rockafellas, Rothchilds......  are all (at least most) Jewish / Zionists who are never satisfied with what they have and must continue their planned conquest of the entire world. They are money hungry and it makes sense that they would detest any free energy that does not have a meter on it!! Just like negative Jewish influence that had Nikola Tesla go bankrupt due to his free electricity without wires give away!
Now then, it begs the question........is this "overunity.com" forum influenced in any way?
YES, YES...all things are possible and I don't regret or give a shit what you all think as to why I posted the following link!!
http://en.wikipedia.org/wiki/Moritz_Hartmann ???
Shlould we be afraid or should we continue to open-source all knowlege about
chep supply with needs about Energy.
If someone lifes like a parasite on my neck, i will stop to feed him.
I try as less as possible,  to employ a bank to distribute my money.
Cash ist best.
helmut
nitinnun
i discovered another insight.
a counter-clockwise coil is needed in the peak. to convert the clockwise spinning peak energy, into counter-clockwise spinning hot-electricity!
i think that cold electricity has a clockwise spin.
which is why it is conducted through clockwise spinning protons. ignoring electrons and their electrical resistance.
i think that the normal hot electricity in our walls, has a counter-clockwise spin.
which is why it is conducted through counter-clockwise spinning electrons. ignoring protons.
the nazi's were illuminati.
the nazi's swastika had a counter-clockwise spin.
the counter-clockwise spin is death energy.
the all seeing eye on the back of the dollar, represents the illuminati.
the peak-antenna needs a counter-clockwise coil, to produce electricity.
so the all seeing eye, has a counter-clockwise spin.
the illuminati are powered by the counter-clockwise death spin. just like the nazi's swastika was coutner-clockwise.
bigbriggy
I have been following this thread for a while now and i have been intrigued by the discussion of using a pyramid for harnessing natural energy - having listened to other people discuss power generation. i found the Tibet flag has a peculiar set of items in it which lend itself nicely to the discussion. if you notice the user of colour like positive and negative (could be in relation to waves or yin or yang). then we have the pyramid object - with something hanging down from the roof - with a symbol on the floor coming up to meet it but not quite.  and of course the sun like object at the top of the pyramid.... may be nothing or just a coincidence but could be food for thought.
http://bp1.blogger.com/_QiZluUixU0o/SGKzgmWvmEI/AAAAAAAAAA8/halTBvh8EcA/s1600-h/tibetflag%405b11%405d.jpg
Again, thanks to the guys looking into building the pyramid it looks like an excellent project and i look forward eagerly with any results you may or may not find.
Oh and another link i found very interesting - and discusses the pyramid in a different light is this video, could help on the design on the pyramid your building :)
http://video.google.com/videoplay?docid=-1523833666089029157
gl with your endeavors
