this pyramid should produce electricity. (thomas trawoger's pyramid explaned.)
Started by nitinnun, July 16, 2008, 04:57:47 AM
nitinnun
.....yesterday i came up with A TON of new insights!
i could barely sleep, because they kept poping into my mind.
most of it is "convincing theory", and some of it is stuff that i doubt anybody knows.
the result is that i will have to make serious changes, to my plans.
some of them need entire threads devoted to them!
i'm overwealmed at the moment
i'll post them once i have them nailed down more.
sirmikey1
There is so little power coming from this device, that I wonder if it's
largely static, galvanic, or chemical, or a combination reaction with
all of that crap on the device.  Many many ways to come up with a
good workable volt or two, but no real amperage.  Well, at least it's
a start...
SM
nitinnun
in the last few days, i figured out that les browns pyramid, thomas trwogers pyramid, and the great pyramid in egypt, all required saltwater to work.
that all of them work on the same physics, as water cells.
but in their case, the clockwise spin around the kings chamber "charged up" the copper,
and the CCW spin above the peak, "charged up" whatever was used as the negative metal.
i was thrown off by les brown, because i didn't realize that the water/salt/electrolytes in his body, is what caused his pyramid to work.
i saw the connection between my water cells, and the saltwater in thomas trawogers pyramid, but the function didn't click until recently.
the information that i came up with, likely deserves its own thread.
it explains how the egyptian pyramid created electricity.
i'm still putting my thoughts together.
and i have to refine my drawings, to explain it better.
nitinnun
clockwise spin,
plus counter-clockwise spin,
equals electricity.
water generates more CW, than CCW
(from 2 diamagnetic hydrogen atoms)
sand generated more CCW, than CW.
(from 2 paramagentic oxygen atoms)
CW builds up in positive clouds.
then rain drops conducts CW down to earth, as lightning.
electricity spins CW AND CCW.
hydrogen atoms in water conduct CW, but not CCW.
oxygen atoms in water conduct CCW, but not CW.
water conducts CW and CCW, WITHOUT merging them together into electricity!
(like copper wire merges them together)
CW energy is not readable by electronics!
(people mistake CW energy, as orgone/ether/whatever)
CCW energy is not readable, by electronics!
(people mistake CCW energy, as negative-emotions/curses/mortal-terror/whatever)
only electricity, is readable by electronics!
(CW mixed with CCW. both discharging each other, out of existance)
water allows CW to build up in copper, and CCW to build up in steel.
salt REALLY conducts CCW. so saltwater conducts even better than water.
saltwater does corrode the metals.
but the energy, comes from CW from air, and CCW from the earth. not "just" from corrosion
atlantians used gold as the positive, and copper as the negative.
gold and copper were more resistant to saltwater, yet still conducted the clockwise spin and counter-clockwise spin.
atlantians compressed saltwater, to make it an even more efficient conductor of CW and CCW.
vibrations in grand gallery, excited saltwater. making saltwater an EVEN MORE efficient conductor, of CW and CCW.
atlantians split saltwater, with hydrolysis, in queens chamber.
then pumped oxygen outside, and pumped hydrogen/sodium into grand gallery.
hydrogen/sodium, was better CW/CCW conductor, than saltwater.
antenna for CW, and antenna for CCW, were both in grand gallery.
both antenna's touched the same body of hydrogen/sodium.
CW antenna sat at top of grand gallery.
CCW antenna, was moved from bottom of grand gallery, to top of grand gallery.
the closer the 2 antenna's got, the less amperage loss between them.
the space between them, was used to control how much amperage was produced.
when an atlantian was recharging his motorcycle, CCW antenna was at bottom of grand gallery.
when an atlantian was recharging his bus, CCW antenna was in middle of grand gallery.
when an atlantian was recharging his floating gunboat of death, CCW antenna was at top of gallery, right next to
CW antenna.
