this pyramid should produce electricity. (thomas trawoger's pyramid explaned.)
Started by nitinnun, July 16, 2008, 04:57:47 AM
CLaNZeR
Quote from: nitinnun on July 16, 2008, 04:57:47 AM
if you do not understand this explanation, than you will likely never build a setup, that
harvests electricity from a pyramid.
Hi Nitinnun
You sound very confident in your design, have you built one? or is this your theory and idea on it?
Cheers
Sean.
http://www.overunity.org.uk
nitinnun
no. i have not. i posted it shortly after making the mental-breakthroughs that gave it too me.
i'm as confident as i am, because i know how the energy physics work.
because there are no more gaps in my knowledge.
i'm also confident, because i can "see" my design working in my mind.
i can see the pyramids magnetic current pushing magnetic energy, into the capacitor. then trapping the magnetic energy inside the capacitor, for electronic use.
like one balloon pushing air into a second balloon. until both balloons have equal air pressure.
if my design doesn't work, than it will be because 1 or 2 minor details need to be changed. not because what i showed you is false.
i've already given you more useful information than thomas "cluster-mid" thawoger did.
thomas thrawoger just gave you a long winded video of him talking and smoking. which didn't even show much......
martinzurix
setup is very simple maybe someone tray this replicate ?? i don`t  have garadge and tools to make things only hope is in peoples in forum.
if its get worked then i go to countryside and make one there.
if such pyramid is placed near HV wires maybe it will suck energy from there too ??? :D  8)
nitinnun
power tools are not required. you could do this:
1: cut copper foil into triangles.
2: punch holes on their edges.
3: zip-tie 4 triangles together into a pyramid/peak. (if all 4 triangles touch electrically, than it will work).
4: cut 4 large cardboard/wood/whatever triangles. as long as they are electrically non-conductive!
5: wrap aluminum foil around the base of each cardboard triangle.
6: hole punch the edges of these wrapped cardboard triangles, and zip tie 4 of them into a pyramid.
7: place the copper peak on top.
8: place the peak and base antennae's inside.
i loath building things. yet ironically, i am good at designing them.......
martinzurix
is important to make `nonconductive base`  empty or solid ?
150mm X 150mm in scale is enough for maybe lighting one LED ?
