this pyramid should produce electricity. (thomas trawoger's pyramid explaned.)
Started by nitinnun, July 16, 2008, 04:57:47 AM
jeanna
Quote from: Rocr on July 18, 2008, 07:47:10 PM
It will be a bit large and have several illustrations from the papyrus to get the concept across ..but I think you will find it interesting ..
I think you and the people here are the one I've been waiting for to flesh this out in scientific terms ..
Rocr
there is a separate thread for general pyramid discussions
http://www.overunity.com/index.php/topic,4045.0.html
I for one, look forward to your information. I am sure there are many others too.
jeanna
nitinnun
since the peak of thomas trawogers pyramid was both steel AND electrically connected to the negatively charged base, i'm surprised that he could even get enough electricity to power a computer fan from it.
trawoger gave you lots of stuff alright.
lots of useless stuff. that didn't teach you what you needed to know, to succeed.
don't use that steel pyramid as a lawn ornament. it will rust like mad in the rain!
and contaminate the soil with iron oxide!
his very pyramid design will poison the earth......
nitinnun
now that you mention the pyramids from old civilizations.....
some of those pyramids, didn't have peaks on top. instead, they had flat platforms.
the reason why they had flat platforms, is because they placed gold/copper peaks on those platforms! and walked into the peak through a door in it!
(they wanted to be able to walk into the peak, where all the power in tehir pyramid was. so they built that way.)
more proof that a large mass of positively charged metal, sat on the peak!
and that it was never grounded!
jeanna
I have made many pyramids using poster paper. It should work for this.
I will cover the top with copper and maybe nothing at first on the bottom just the cap inside.
In fact when TT first posted his patent, I cut a hole in the side of one of my retired pyramids and put a capacitor in from the peak to the base. - no battery recharge and no spark.  I didn't, however use the copper on the peak. I think this worth a go.
2 things.
1- I put "tabs" on the sides of the triangles. This makes it much easier to tape the edge nicely without gaps etc.
2- nitinnun, placing a pyramid over you when you are lying down is a very good way to get rid of a malady. Especially a headache or a bellyache. just put the hurting part under the middle of the pyramid.  Line it up to the north. You will begin to feel warm and the pain will dissapate in 10 minutes , usually less.  I used to use this a lot. If I had a bad headache I would usually fall asleep, I think from relief.  Just poster paper, though. I don't think the metal version would be helpful to your body, but I know for sure the paper kind works really well.
thank you,
jeanna
nitinnun
* remember that the pyramid may have to be charged up, to start the reaction.
just like you need to make a snowball and push it down a hill, to get an ice-boulder rolling.
* a one-material pyramid not only has the same magnetic capacity at peak and base. but the peak and base are also connected.
a one-material pyramids positive and negative polarities, cannot get far enough away from each other!
because the one-material cannot have a strong maximum charge, in both positive and negative energy!
the copper must have the strong positive capacity, and the aluminum must have the strong negative capacity.
and what little distance its polarities can sepperate themselves, is made even shorter. because then the charges discharge, when they meet in the electrically connected middle!
* if you electrically sepperated the peak and base of a mere paper pyramid, than that alone would increase the capacity of the pyramids magnetic field, by several times.
because then the paper peak and paper base could charge up higher, before discharging in the middle.
my glue cells respect this energy requirement. because the glue which connects the copepr and steel, is electrically non-conductive.
so the copper can positively charge up, without the steel discharging it.
and the steel can negatively charge up, without the copper discharging it.
* the copper peak greatly increases the positive capacity of the peak.
the aluminum base greatly increases the negative capacity of the base.
* but on top of that, i think the copper and aluminum together, form a diode effect. a diode effect whcih is IN ADDITION to the diode effect of the pyramid shape!
because electricity flows easier from copper to aluminum. while in a 100% paper pyramid, the energy can flow anywhere.
like i said before. even if there is something missing from my pyramid design, than my design is still much closer to success, than what was known before.
without supporting some of the basic energy physics which my design supports, success is extremely minimal.
just as you need certain materials and a certain design, to have any chance of building a car engine. or a nuclear reactor.
