this pyramid should produce electricity. (thomas trawoger's pyramid explaned.)
Started by nitinnun, July 16, 2008, 04:57:47 AM
nightlife
sirmikey1, your video shows volts but does not show amps. You must show amps too and I bet that the amps are a lot lower with the DC voltage then with the AC voltage.
sirmikey1
Quote from: nightlife on August 18, 2008, 09:47:56 AM
Nightlife,
What's your take on this one?
He has put several in series and has it up to 200ma 13watts 90volts
http://www.youtube.com/watch?v=Kdup42Epq0o
SM
nightlife
sirmikey1, I am not sure if that was the right video becuase it did not show the results you posted it to have and it was a her and not a he. Lourie Matchett.
It was interesting to say the least although I would have to know more about the power of the frequency supplied. I will toss it around in my head today and post a better opinion this evening.
sirmikey1
nitelife,
  Lourie has several in series, getting the 13watts.  You can see it in the comments.
You can do similar with with a simple copper tube antenna, 20ft in the air, ungrounded,
with a pole deep in the ground as the ground.  20volts 25ma.  Series a few dozen of
thosel
SM
nitinnun
the paramagnetic oxygen/calcium  atoms in gypsum, attract CW into the pyramid, from the air.
it might be easier to just fill a pyramid, with sand.
sand has 2 oxygens atoms per molecule. so it is also paramagnetic.
the copper loop was full of sand. that sand collected/stored CW as well.
