Selfrunning Waterpump-generator device runs 60 Watts lamp...
Started by hartiberlin, July 16, 2008, 03:09:31 PM
khabe
Quote from: BATMAN on July 23, 2008, 05:15:21 PM
BATMAN ...HERE HI ALL
Here is pic of 10,000 watt gen. hook -up to turbine shaft.
have fun ...BATMAN
Amazing - exhaustive information !!!
Have look at http://www.thelivingmoon.com/41pegasus/33roberts_files/index.html
Mr Jackson, unfortunately no reply to my modest question, hi has much more ideas!
He does the same like Selfrunning Waterpump-generator - with AIR !!!
Attn: fritz - no wonder kinetics of water !!!  >:(
http://www.thelivingmoon.com/41pegasus/33roberts_files/Air_Generator_10-136063.html
He has very train of thought about how watermachine works:
"...Pressure from thrust of water coming from water pump through the water pump nozzle X-Amount of pressure on turbine that is attached to generator Torque created by turbine (which is being rotated by thrust of water from water pump) = X-Amount Generator converts torque into electricity which in turn runs the pump
1/6 of Torque = Horsepower
1 â€" Horsepower = 755 Watts
Watts ? Voltage = Amperage
I believe Amperage created by the Generator
will be greater than Amperage needed to run the pump."
:o
Now its clear!   >:(
But he was not pleased with  - why to play with water or air? Why to play with pumps, why hoses, why all these stupid things ????
And he did it!  No water, no hoses ...  :o
http://www.thelivingmoon.com/41pegasus/33roberts_files/Dynamoto_Electric_Generator_11-009798.html
final solution -> Dynamotor Electric Generator  :o
khabe
robertjackson
@ Khabe  I don't have a working prototype but I like to think its because I never could afford the right componets (mainly generator). Your right after messing around with my hydro and air prototypes I thought why not just connect an electric motor directly to the generator. I came up with all sorts of combinations with different electric motors and different generators and alternators . I do believe that the right motor and generator could be developed to make this basic concept work. After doing everything I've done I think the high pressure water or air generators are the best way to go.  I personally have put everything on the back burner about 1 1/2 years ago after being dianose with a pretty serious medical condition and to be honest its got the best of me. Well anyway, I hope the best for anyone to build a working prototype and to go public with it. If this should happen I wouldn't doubt that some big corporation would come forward and claimed that they already own the patent rights and at the same time alot of people will probaly come out of the woodwork claiming the idea as there own. Personally I thought of the basics to the hydro generator in the late 70's but didn't start keeping a documented timeline until October of 2000 on my hydro, air, and solar ideas ( I have over 100 envelopes that I mailed to myself) There is a very interesting story in those envelopes. I actually believe these concepts are to basic in nature to be patented and I have tried to open source to ideas for over 5 years now. If anyone wants to patent something it should be a better generator, better pump,better motor, better turbine, or whatever it takes to make these concepts work.
tishatang
@robertjackson and all
My two cents for what it's worth.
If you are going to match a motor with a generator, then do it with a direct coupling, not V-belts.  Use a 3450 rpm motor with a 3450 rpm rated generator, etc.
Why introduce extra losses.  Better yet, make it a motor/generator with no coupling losses.  See Dyna-Motor patent here:
http://www.rexresearch.com/alxandr/alexandr.htm
Download and read the patent where it is claimed 3 times output vs input.  According to Peter Lindemann, replications failed at the time the patents came out.
You are better off with the water pump scenario where you introduce momentum and velocity times mass with the accelerated water.  However, even if it does work, the water will heat up because of the work done to the water.  I have run small pumps, 1/15 hp  outputting 120 psi in a large aquarium sized tank.  The water will get quite hot after a while and requires a shutdown to prevent overheating of other parts of the system I was testing.  Of course you could always build two units and let one  rest half the time.
Tishatang
4Tesla
Quote from: khabe on July 23, 2008, 04:01:30 AM
Dear Mr. Jackson,
I hope you have not paid for electricity past 25 years - you have own Self Powered Hydro electric station  -  how many units you need per house and how many kw/h you have generated for these years?
Best regards,
khabe
PS:
4tesla wrote:
_"What is cool about this device is that it would be very easy to replicate.. only problem is money.  I don't think there is anything special about the generator."_
I can not agree!  How much money?  What is cost of one pump? $300? 500? What is cost of few meters of hose?  Very expensive playwood? No screws ...
No way to find generator? Or does it mean - FREE ENERGY - that all must to be done for nothing - nothing spent, nothing done - just pick your nose and get it free  ...
Well it is a problem for me.. I don't have $500 for the pump and generator.  Not everyone has hundreds or thousands of dollars to work on these projects.  Pick your nose if you can't think of anything nice to say... maybe it will help clear your brain.
Jason
khabe
Was not meant to insult - just for give encouragement - to accelerate process ...
Get some loan - after that you have not to pay for electricity - you will sell it to all city  :o
Its Friday today - what's up about promised new setup?
khabe
