Selfrunning Waterpump-generator device runs 60 Watts lamp...
Started by hartiberlin, July 16, 2008, 03:09:31 PM
hartiberlin
HI James,
depends on how much empty space you have on your generator..
But I guess 200 Windings EACH with at least 3 millimeter wiresize diameter
should be okay to run your pump
fritz
mmmmhhhhhh.....
thinner wire == higher resistance == more heat ==more space
thinner wire / more turns == higher voltage == more pump rpm== even more heat
thicker wire == lower resistance == less heat == less space for turns
thicker wire / less turns == lower voltage == less pump rpm == lower heat
Hi !
Normally there would be kind of stabilizer/regulator in such setup which controls
the current of the rotor (like the regulator in a car generator).
If the output voltage is too high (means also output current high) - such regulator
would "chop"=="reduce" the rotorcurrent== rotorfield to protect the system.
If you don?t have such thing in your setup - I would try to do the same amount
of turns with thickest wire possible. Any change in turns changes the output
voltage == pump rpm/power.
What concerns CW/CCW  - I would stick to the proven orientations ;.)))
rgds.
666666
James: It would help if you could give any details that you know about the generator. For instance with a capacitor regulated generator, it is easy to raise the output voltage by just adding a larger Microfarad capacitor until the desired output voltage is reached. I assume this is what you are trying to do. However It appears that your generator is self excited so I will have to agree with Fritz on that one. It appears to me that your generator builder is a "cut above" most most motor re-winders. I would have to say that the generator is wound with finer wire to increase voltage and the capacitors are in series with the output to impedance match the system so that the High resistance in the fine wires "DISSAPEARS". If this is the case and I am quite sure it is you might be able to solve the problem by using a capacitor decade box to tune the capacitors to the inductors "better". I could easily tell you exactly how to do this if you could tell me the existing Microfarad rating of the existing capacitors. Are the capacitors dual electrolytic caps in series? If this is the case it is imperative that you hook them up plus minus minus plus in series so they can work in a ac circuit, otherwise they can/will explode. The reason you would use electrolytic in this manner is they pack a lot of capacity in a small package and can work in a ac circuit even though this is not what they are designed to do. If you wire the generator with less windings and your generator technician already impedance matched it, you will have to re tune it after winding. If you need to know how to do this let me know and I will try to run you through the basic process and make it as simple as I can.
Remember that impedance matching should reduce heating in your windings "AND" increase output voltage and amperage. I am assuming this is your goal. I would also suggest that you test your capacitors on a good capacitor checker. You will have to find a good electronics engineer to do this because a good checker costs well over 8000 dollars. I can tell you a simple way to do this yourself if you are interested.
YOUR TURN
Pirate88179
@ James:
Look.  You are here on a public forum that is frequented by a lot of really intelligent, dedicated researchers and experimenters.  Unfortunately, not everyone here has the same goal in mind.  Some just like to rip into people because they themselves did not, or could not, come up with anything new.
Please don't let one or two folks here stop you from posting on this forum.  Most of us "want" to learn about energy and different ways to create and utilize it.  Please ignore the rest and stay until we can all together determine what exactly you have going on here.  You will find a lot of smart guys that can help you, and you can help us.  We are all in this together and, if you indeed found some breakthrough method with your device, we are all ears.
Put it this way, you could be the Wright brothers back at the turn of the century and post here that you found a method of flight.  A lot of us would be excited and helpful, still, some would say..."no way, you faked the flight".  I am sorry that this is the way it is.  Just read the posts from helpful folks and ignore the rest, and keep us in the loop.  I am sure there are a lot of folks on here that agree with me.  If you discovered some anomaly with generators, and caps, and water pumps, we need to know about it and go from there.  I hope you remain with us.  Thanks.
4Tesla
Quote from: Pirate88179 on August 19, 2008, 10:58:32 PM
@ James:
I agree..
Jason
