Selfrunning Waterpump-generator device runs 60 Watts lamp...
Started by hartiberlin, July 16, 2008, 03:09:31 PM
666666
I have duplicated the James hardy self powered setup without the generator.
It consists of.
1. T-10,000 pump which he confirms is exactly the same pump he used.
2. Wheel with paddles, exactly what James used with cupped washers which was specailly formed for more torque.
3. Watertight plastic container.
3. Ballanced motor shaft and bearings.
4. Clear hose with all adapters necessary teflon sealed with the same nozzle James used.
5. This has been tested and works well, exactly like James's unit.
6. I have attached photos so you can see what I have done.
7. I am thinking of selling this for exactly what I have in it, no charge for my labor. I need the money to get my home finalled.
My speculation is that the device gets its power from water hammer. Watch James's video again and note the change in the appearance when the water gets the air bubbles mixed in. It gets milky, then the rotation speed increases dramaticly. I have seen the results of water hammer caused by opening or shutting the valves when a repair has been made. It blew all the valves of the mains going to the homes on a county water system for 500 feet. They were burried over 10 feet and the whole section had to be dug up and repaired. Thousands of pounds of pressure can be exerted from this effect and pipes can rip open for many feet. I filed for a provisional patent. If anyone asks I will send a copy or if there is enough interest I will post it as an attachment. Water hammer was how the Richard Clem device worked. He worked in the utility department for the county and saw the effects of Water Hammer.
khabe
Wonder you found exact the same "tablespoons", fittings/fixings and the same washingmachine pulley ::)
8)
cheers,
khabe
lanblan4
666666.
Nice job I am very interested in purchasing your set up as shown, I have seen Mr Hardy's device working and he has added triple the amount of paddles to the belt wheel, but it should not be to much trouble to add the rest of the paddles myself. Please email me with the price you are asking or we can talk over the phone? If your still interested please contact me.
Thanks
Waiting for your reply
khabe
Why phone or email when you are in the same room ???
cheers,
khabe
P.S.
Billionaire did not carry out any money?
nitinnun
imagine your mouth,
using air pressure,
so suck liquid into a straw.
i wanted to make my own pump.
using an enclosed box fan, to suck water through a tube.
or maybe bind the box fans blades,
with zip ties,
to a water tight turbine.
and the turbine would actually touch the water.
i also wanted to make the main body,
out of gorilla glue smeared cardboard.
gorilla glue would soak nicely into the cardboard.
gorilla glue is immune to water.
gorilla glue would seal up any openings, in the cardboard body.
i also wanted to use tesla's air turbine, instead of the water wheel.
the tesla turbine would be made of 6 gorilla glue smeared squares of cardboard.
with 1/4 inch sepperating each cardboard square.
the water would flow through the 1/4 inch gap, between the cardbaord squares.
the friction of the water sliding against cardboard, would turn the cardboard wheel.
the tesla air turbine, was said to be 98% efficient.
i imagine it is just as efficient, with water.
i'm typing this, because i want someone to use it.
i don't give one rancid d*mn, about getting rich.
or even about recognition.
i want the world,
to be a better place to live in.
