Linnard?s hydrogen on demand system without electricity !
Started by hartiberlin, October 04, 2005, 06:54:25 PM
ResinRat2
Hi Edelind,
I would agree with you, they are probably more efficient at gas output, but i have worked with hydrochloric and sulfuric acids in the past, and the the chlorine and sulfer smells are highly unpleasant so to say the least. That is why I am sticking with the Hydroxide reactions.
edelind
As soon as I will make my colloidal Magnesium solution and get the acids and zinc/cobalt sulfates I will try that for myself. I am still hoping that the hydrogen will come out clean! :) I'll post the results here.
ResinRat2
That's great edelind, I suspect your results would be very good.
I am wishing you the best of luck on it.
ResinRat2
Just some pictures during the leak test with deionized water. So far it looks good. No leaks, even between the inner chambers. EXCELLENT!!!!
Got my fingers crossed.
It holds a total of ten liters of liquid. The center glass wall that seperates the chambers has four - 4 inch holes. Each covered with 1 micron filter nylon mesh. This is to keep bubbles from crossing chambers. Thats what the cloudy area is between the chambers. It has a total of 52 - 1/4" tungsten carbide electrodes and 14 - 1/16" thoriated tungsten electrodes I had left over from previous experiments. The two zinc rods are 5/8" diameter and 12" long each.
Thanks for your interest.
Mark69
looks great RR, good luck! cant wait for your results :)
Mark
