Linnard?s hydrogen on demand system without electricity !
Started by hartiberlin, October 04, 2005, 06:54:25 PM
Tacmatricx
Hi RR,
She's still running with no changes! other than minescule voltage changes... I see no reason to touch it at the moment.
Here are the Pics as promised...
Graveyard... Previous zinc electrodes eaten to foil
H2 Gas... Shows H2 production when tilted, only way to get a decent pic
Regen Side... Shows color of the zinc electrode which has been running now for three days and does not appear to have erroded
Tablespoon reactor... Single test tube design with two 5Ohm resistors in parallel
Tacmatricx
Tacmatricx
mscoffman
Quote from: Tacmatricx on August 27, 2008, 08:57:51 AM
Hi RR,
Tacmatrix;
That's fantastic! There is not much room in there for any reaction exhaust products in there, is there.
A couple of questions:
(a)Does it seem to be running at room temperature? or is it endothermic - refrigerating it's environment?
Maybe you could keep checking for a delta to room temperature. (b)Is that castolite plastic at the bottom
of the test tube to keep the elements aligned? - If it is I wonder if you could put a sealent like RTV silicon
sealent over top of it in the next one. I'm wondering if maybe the reaction is getting to the carbon of the
plastic in these reactors and using it for fuel. There is such a tremendous apparent energy imbalance
in this reaction.
:S:MarkSCoffman
Tacmatricx
Hi Mark,
The cell is made using the following:
Pyrex Test Tube,
Lab Rubber Bung
Tungsten electrodes
Zinc electrode
Shrinkwrap - Red and Blue
Standard Cable ties to separate the electrodes, hold the electrodes together in alignment and to breach an airspace next to the bung to allow gas to escape.
Wax cord tied around to mark the electrolyte level
I have done basic tests where I placed the reactor in a water bath and monitored the temperature against an identical bath with no reactor. No temperature difference was observed... It remained at room temperature.
in this reaction.
It's all cable ties which I have used as spacers over and over with no discoloration and apparently no interference in the cell.
Can't explain how or why this all works any better than the Linnard Patent of the reaction. It's entirely balanced with the application of a small current to keep the zinc plated. It behaves similar to a catalyst in that the materials are not consumed but dislike a catalyst in the fact the materials directly react.
Chris
