Linnard?s hydrogen on demand system without electricity !
Started by hartiberlin, October 04, 2005, 06:54:25 PM
ResinRat2
Hi Chris,
Sorry, I lost my temper; but I changed my post so its not important.
Let's just go on from here as if it never happened.
Sorry.
ResinRat2
Hi Chris,
Sorry, I've been gone all day and just got back a few minutes ago.
Just to let you know, I plan on finishing the sealing of the zinc tubes, probably by tommorrow. I think I will use silicone sealer both inside and outside of the zinc electrodes.  So that should finish that.
The tungsten electrodes I will try and seal the same way. If it holds, then it will hold. Otherwise I will try something else.
Thanks again for all your help.
Dave
Dingus Mungus
Just a note: I haven't tested silicone sealer for compatability... So you may want to dip a dry bead in some solution for a few days. Also something to remember; even when a plug was snug and dry I still got air bubbles that turned in to channels once the hydroxy was introduced. So really glob it on there till you got to hammer that plug in. LOL! Sorry again that I couldn't finnish up the leg seals. My apartment complex has since backed off since I told them I shipped it all away. Thank you so much for carrying on the PVC reactor project!
Gearhead
I am sorry for my poorly worded post.  It should have been phrased as a question.  I have been following this thread for weeks.  It has been very interesting.  Thank you for all of your hard work and discussion.
What intrigued me was that following the addition of an aluminum electrode, the next innovation by Resin Rat was to seal the aluminum from the electrolyte with zinc.  Now the aluminum is not an electrode.  It must be something else.  I was wondering what that something else is.  Aluminum can collect free electrons from the atmosphere that tunnel through the oxide coating.  Is this what is causing this new phenomenom?
Could it be acting as a diode?  Is this a new principle?
jdkeeler
That is a good question. I've used tungsten ,silicone carbide bi electrodes and had more questions about the mechanism.
