Linnard?s hydrogen on demand system without electricity !
Started by hartiberlin, October 04, 2005, 06:54:25 PM
Paul-R
Quote from: ResinRat2 on November 10, 2006, 04:07:56 PM
Hello everyone,
Well, I have to admit, I honestly did not expect it to work, but my experiment is a success. I placed the electrodes into the solution and no gas was produced until I connected the wires between the electrodes. Just like the patent described, the evolution of gas began.
I have buddies here at work who were very interested, and now we are convinced.
I will need to collect the gas to see if it is flammable, but that won't be for a few days.
Just wanted to let everyone know. I duplicated experiment #13 of Linnard's patent.
Free hydrogen is now a reality in my lifetime. Man am I blown away.
Talk to you all later.
;D :o :D ;D
BEWARE OF SEEING IF IT IS FLAMMABLE.
If what is coming off is H2, no problems. If it is a stochiometric mixture of H2 and O2, which is the result of various new technology electrolysis experiments, then you may get your equipment BLOWN TO BITS. You could try bubbling the gas through soapy water, and chase after the bubbles with a lighted cigarette lighter. If it is H2, then you will get a wispy blue flame. If it is H2+O2, you will get a sharp crack.
People on this thread more learned than I should be able to predict with certainty which gas must come off. But don't make a mistake.
Paul.
hartiberlin
Hi ResinRat,
many thanks for your sucessful experiment.
A  I don?t yet have Tungstencarbid, I wonder, if it also works with just Tungsten electrodes, normally used for welding ?
All the other materials I already have and when I have some free time, I will also try it.. By the way, could the colloidal magnesium also substituted by colloidal aluminium and the colloidal silver be substitute
by colloidal lead ?
This would be cheaper to produce and I have a colloidal silver generator device. By the way, you can just use 3 * 9 Volts batteries in series to put onto two silver rods or two magnesium rods to get colloidal metal in a 80 degrees celsius heated destilled water baker. So 27 Volts DC half an hour applied to two metall rods in hot destilled water will produce colloidal metal in destilled water. Maybe some other guys could please also try it. Yes and be cautious, when you try to ignite it. When it is oxyhydrogen, the baker will explode ! Use a hose into a bubbler with soap water and extract a few bubbles and ignite them outdoors and see, if they explode or just burn only...
hartiberlin
Where can we get Tungsten Carbid cheaply from ? Will also Tungsten carbid powder work put next to a Tungsten Carbid rod ? Thanks.
ResinRat2
Stefan,
According to Linnard's patent, any metal can be used in colloidal form for this reaction. The rate of the reaction will depend on the reactivity of the metal, Silver being one of the fastest. I didn't even consider lead because I am chicken (lol). I just wanted to duplicate Linnard's work.
As far as using tungsten pure welding rods, I believe that is what I am using. The label on the package of the rods says it is pure tungsten, and I purchased them at a welding supply store.
Also, don't worry guys. I'll be very careful and try not to blow myself up. That's why the experiment is running in the vent hood. No flames will go near it for now.
By the way, it's still running. Same look, same rate (estimated by appearance), and I guess I'll leave it running through until Monday.
Thanks for the interest.
hartiberlin
Hi ResinRat, many thanks for confirming, that you just use pure tungsten and not tungstencarbid. Then I can try it with my materials over here. Maybe you can also try it with different colloidal metals, as magnesium is pretty expensive compared to aluminium and also silver compared to lead, so if it will also work with cheaper metals that would be nice. It seems due to this Re-Dox reduction it works like a shortcut battery that self-electrolyzes its own elektrolyte and because this Redox chain reaction the electrolyte is always regenerated and thus only water is consumed. I wonder if we could also use the 0.3Volts to light a minilamp or drive via a Dc to Dc converter also other loads with it ? ResinRat could you please measure the DC current between the electrodes when you shortcircuit the wires ? How much DC power can we get out there ? With bigger cells we could probably also get higher amperages or put several cells in series and get higher voltages. So this would also be a free electrical energy genertor additionally !
