Linnard?s hydrogen on demand system without electricity !
Started by hartiberlin, October 04, 2005, 06:54:25 PM
ResinRat2
Hi Trump,
Thanks for offering to help. My clear acrylic material is finally scheduled to arrive tommorrow, so I will finally begin building the reactor. Might take a few days or so. In the meantime no one can really help me directly, but if you have any ideas then go ahead and post them. I am open for suggestions and observations.
It certainly took me a while to get to this point, but I still feel like I am taking baby steps in the dark. --- lol. :D
yikes
Learning test number 2.
I went to Walmart, got a 5 compartment tackle box 4"x9"x1", cut 1" off the dividers between compartment 1 and 2, and 4 and 5, center was left alone.  Drilled some holes in the 1" top.  Put 3 SS deck screws in compartment 1 and 4, put a zinc 20d nail in compartment 2 and 5.  Put a short piece of copper tube in 1 and 4.  Put copper wires to the screw and nail.  Sealed the edges with epoxy glue, closed the top and weighted it down and left it for 2 days.  Tonight I filled it with solution, attached tubing to the copper stubs and took it out to the lawn mower.  Started the mower and turned in the gas metering screw until the mower was running very rough, barely able to keep going.  Pulled off the air filter and put the tubes in the manifold.  Twisted the copper wires together and waited.  I was not getting very many bubbles (I'm glad about that)because I failed to clean the coating off the screws.  But the motor smoothed out and ran normal.  After 15 minutes I shut off the gasolene.  The motor ran for 20 minutes and died.  There were way too few bubbles to keep the motor running so it stopped because fuel was used up in that had been in the fuel bowl.  But, there were enough bubbles that it helped the motor run.  I will be doing some more tests like this in the next three days.
Now RnR, I know that this is not the testing that you are doing here, but I needed to get to know hydrogen a little better and this seemed a decent way.
I wasted yesterday trying to find tungsten carbide drill bits.  What I was looking for were 1/8" x 4".  I wanted to see if the design of a drill bit would be any value in getting the hydrogen bubbles off the tungsten rod.  I had thought to punch several bits through a copper plate and place that at the bottom with a copper wire coming out the bottom.  Sadly I couldn't find any except for micro bits that were only 1 1/2" tall.  So for now I will just get the welding rods.  Like I said, it will take some time for me to catch up, but I haven't left.  Hope that you are having fun with plastic.  I am anxious to see your design configuration.
Trump
yikes
It was good to see your post. Is your intention to make a hydrogen unit so you can run a motor on it, or are you just doing that for now and then, change over and concentrate on what ResinRat2 is focused on? Just by what you did it appears to me that you have some knowledge on the hydrogen stuff. Hopefully it will work out so both can benefit from the testing.
Trump
yikes
Hi Trump,
I'm just waiting for the "stuff" to arrive.  But until then, I want to keep my fingers in water.  I have other interests as well, but in this thread it's all about the work that RnR is doing.  And just between you and me, I even dragged out my old "Chem 101" books so that maybe I won't embarrass myself toooooo badly.  I will have 3 months without work soon and it is my hope that I can do some of the mundane type of testing that can eat up time, which will be fun for me and hopefully a help to RnR.
Trump
Great yikes,
Sounds like there is a couple of forums that are really doing good, This one and also Free Solid State/mechanical Energy forum. I am still reading a lot about Nikola Tesla Patents. I am keeping my eyes open on both forums, at this time.  I don't  have a chemistry background, sorry to say. I watch and listen at this time. ResinRat2 has really did a lot of work on this forum.  There has been some slow times ,but even so he has stuck with it. I have no doubt that he will get it to work, how much will it generate when he is done, well that is a question that I am sure nobody knows at this time.
God bless all of you working on this project.
Trump
