Linnard?s hydrogen on demand system without electricity !
Started by hartiberlin, October 04, 2005, 06:54:25 PM
ResinRat2
Hi Darc,
The final goal is simply to show overunity. A reactor that can run continuously while recycling all components and producing an excess of power through a fuel cell. Ideally it would be completely sealed from the environment and recycle the water as well. What it would really be running on is the ambient air temperature, using energy from the atmosphere to produce hydrogen through Dr. Griffin's electrolysis process which is an endothermic chemical reaction. This hydrogen would then go through a fuel cell and produce electricity which would be used to run electrical devices.
Picture a sealed black box with an outlet on it. The energy would be taken from the air temperature, produce electricity; then the electricity would go through your desired electrical device (motor, etc.) which would then put the heat back into the atmosphere. A perfect "green" cycle.
ResinRat2
Hi Chris,
I believe I found my leak. It was in the top cover gasket. One section had what looked like pinholes in it. I discarded the gasket and am making a new one. This was on the oxygen (zinc) side just as I suspected.
If at first you don't succeed, ....
darchorse
ResinRat2
Thanks for the update - this is amazing - i'm sure you gonna do it!! just adjusting my cosmic molecular disseminator to send you the right vibes to complete this lol
buckeyept49
Where is your spell check? WOW! ordered all today, i have 2 fuel cells i use to seperate hyd & ox with a salt bridge, will try the same with Linnards.
ResinRat2
Hi All,
Dr. Linnard Griffin sent me a short video of one of his reactors working. Look how cool and tiny it is. Maybe I'll be able to build one like this one of these years. LOL.
As long as I can fix my blasted LEAKS!!!!!
Enjoy!
