Linnard?s hydrogen on demand system without electricity !
Started by hartiberlin, October 04, 2005, 06:54:25 PM
Dingus Mungus
I've never tryed KOH in a test cell, but I would assume it works very simularly, as they are both basic (NaOH not Acidic) and they're electronegitivity is still well below the other active metals. I would suggest you attempt a cell with both and campare your outputs and run time. If they're both still producing at the same rates after 100 hours and show the same PH, then you know its stable enough for a long term cell.
Good luck and welcome to the forums,
~Dingus Mungus
ResinRat2
Quote from: keithturtle on July 21, 2007, 02:19:57 AM
Now about those leaks, lemme take yer hand an' walk ya thru this...  (no offense)
Go down to the local hobby shop that sells high-end Radio-controlled airplanes, and git yerself a 1 ounce bottle of "Thin Cyanoacrylate" [CA], medium CA and a spritzer bottle of accellerator.
Thanks Keith, I will try this. I greatly appreciate the suggestion.
Dingus Mungus
Quote from: Bouzouki on July 21, 2007, 08:39:15 PM
Thanks I will try that. Has anyone ever used this solution in a electroliss cell ?
I did some tests with tungsten electrodes @ 24volts (i think)
I had erosion of the cathode and slow building cell heat. Nothing
seemed to be perticularly interesting about the use of the elecrolyte.
~Dingus Mungus
darchorse
ResinRat2
Well done! Thats fantastic - big oil quake in your boots!! It may take sometime but this is the beginning of the end for them - the hydrogen economy is here thanks to you guys. Oh these are exciting times yesss
Darc
