Linnard?s hydrogen on demand system without electricity !
Started by hartiberlin, October 04, 2005, 06:54:25 PM
ResinRat2
Hi Everyone,
Question on youtube for anyone who knows.
This is ongoing research. I want to install the platinum wires directly in the hydrogen reactor to produce a current. I wrapped the platinum wires around the tungsten/carbide rod and started producing hydrogen. I took the other platinum wire and touched it to the liquid surface. So I have a fuel cell. Hydrogen from the T/C, oxygen from the air, and Sodium Hydroxide electrolyte solution.
I get 1.3 volts and only 0.11mA output.
How do I jack up the milliamps? Anybody know?
**********   Deleted Video. I think I know what I need to do.  ********************
Thanks in advance for your help.
hansvonlieven
G'day Dave,
As far as I know, if you want higher voltage, increase the number of cells, if you want higher amperage increase the surface area of your electrodes, all other things being equal.
Hans von Lieven
Suggest making a pipe out of platinum plated mesh and wrap it around your electrodes.
ResinRat2
So you are saying I just need more wire. That would probably make sense.
Thanks Hans
hansvonlieven
G'day Dave,
You would be far better off to make your electrodes up from brass mesh and get it electroplated, more bang for buck!
Hans
ResinRat2
Thanks Hans
I agree, I need to look in the direction of a using a mesh configuration. This was just a quick experiment to show the possible potential of a simple setup.
