Thanks to ALL for your help!!
Pereptual Motion Wheel
Started by Alexioco, July 21, 2008, 02:30:28 PM
Alexioco
Quote from: yoyo on July 22, 2008, 01:18:38 AM
yes your wheels are vary complicated but i liked the videos of your past stuff keep them coming
Thanks my friend :)
I have now tried the mechanism with 3 weights, but I think 4 weights is strong because its two trying to lift two, where with 3 its 1 trying to lift 2, having said that, 2 does lift one at certain times and it could be improved to make 2 always lifting one, but for now, here we go...
the bottom weight pushes down on the right angle which causes the top weight to push out which causes the left hand weight to push out which cause the bottom weight to push down etc etc...
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
Alexioco
Ok I have just found my great one ever...
It would look just like MT 137 if I placed it around the axle...
Its two weights that are trying to lift eachother up to an over balanced point which will keep repeating...
The weights are inter connected and its power is in itself...
I dont want to reveal this here because other people have found good things (not hinting) that wont release theirs, and if I show this it will help them to much and feed their ego's...
Anyway, anyone who is interested in working with me in this, then reply to me at
grandtheftauto_iv@yahoo.co.uk
thanks  8)
Sprocket
Your good ideas just keep coming! :)
Well, I had a go with WM2D but it just sees my effort as a perfectly balanced wheel (file attached)...
Alexioco
Quote from: Sprocket on July 22, 2008, 03:44:54 PM
Thanks sprocket, I'm going to reveal my other mechanism which lookes like MT 137
This is the wheel.
How it works:
There are two levers
Notice that the lever on the right will swing to the right and down, the lever on the left will just hang there.
Now we add the connection between the two levers
Notice that now when the lever on the right goes to swing to the right and down, the oposite end of the lever will push up trying to push the top weight up. As it tries to push the top lever up, the oposite end of the top lever will try to push the bottom weight down in which creates an inward force...
Also, when I was messing around with this stuff today I was starting to realise the amount of ways you can make weights lift themselfs using other etc...
Now that I have showed you this, I would very much like to work with somone based on these things to try and make a way to lift a heavy weight lightly to and from the axle of a wheel without effecting the wheels operation, there a re lot's of things I can go through with you that I have learnt...
ramset
Alexioco amazing ideas !! Chet
Thanks Grandma
