FUEL VAPORIZATION, DOUBLES MILEAGE
Started by dirt diggler, July 21, 2008, 03:34:18 PM
0 Members and 18 Guests are viewing this topic.
dirt diggler
Quote from: ramset on July 25, 2008, 12:01:30 PM
Dirt most of the ideas on this apply to HHO check valves bubblers  not sure about cross over to fuel on another note I wonder what a plasma plug would do here as they   JUST THOUGHT OF A CONCERN PHANTOM SPARK IN YOUR MOWER   Chet PS small one cyl recips spark every cycle [360] BAD backfire risk
Starcruiser:
Thanks for the input!!  You have some great ideas, we will look into possibly using some of them.   ;D ;D
Chet,
Phantom spark
Good thinking Chet, I had NOT considered this.  Clearly we need to think about safety more.
ciao,   Dirt
No, really, I love beating my head against this wall.......
starcruiser
Regards,
Carl
ramset
Thanks Grandma
argona369
Does this hot air/fuel vapor test car help at all?
http://www.race-cardrivers.com/Shell%20Opel.htm
http://www.opel-p1.nl/custom/testcar/Shell%20Opel.htm
Btw,
The air intake to the carb appears to air draw from the crankcase.
Ie the crankcase could also be under vacuum under light loads.
not sure though, but that?s what it looks like to me.
At least it IS drawing air through/from the crankcase.
The crank case must have special seals I would imagine. (if vacuum/ restricted intake to crankcase)
I don?t know what vacuum in the crankcase would do to a normal motor.
it might wreck it?
might just be drawing through, hard to say.
allcanadian
@Dirt
Backflashes are a no-brainer, you put a check valve or flapper valve on the outlet of your coffee can carburator.Ahead of this you put a loose wad of stainless steel wool(dish scrubber pads) which will cool the backflash enough to stop it.The flapper valve is extra insurance to ensure the backflash never reaches you coffee can.
