FUEL VAPORIZATION, DOUBLES MILEAGE
Started by dirt diggler, July 21, 2008, 03:34:18 PM
0 Members and 19 Guests are viewing this topic.
dirt diggler
Quote from: poynt99 on July 21, 2008, 08:09:42 PM
actually, Pogue was from back in the 30's or so. The method and guy you are copying is Tom Ogle. check his patent, he's from the 70's.
He heated his gas tank and ran the engine off the fumes. I duplicated this about 30 years ago as a kid on my dad's lawn mower, and i didn't even heat the gas...strictly cold fumes.
We are not heating the fuel either, although we are considering it, as there are probably more gains to be had that way as well.
So, you say that you did this 30 years ago, and didn't continue with it?  I don't understand why you wouldn't investigate further on a possible way to half gas consumption.
Give it a try again, maybe this is the future of the ICE.
ciao,   Dirt
No, really, I love beating my head against this wall.......
therealrasta
Thanks for the pics.. Glad to see your still working on this.. I would try it, but do not have any small engines to mess with really..And I would hate to try this on a fuel injected system the first time around..
Please keep us informed.. And hopefully some other people will play around with this as well.. Would love to just get 30% increase on gas mileage on one of my vehicles.
Mark69
Hey Dirt, if you run into some trouble with that carb or F/I, find a propane carb setup (like from a forklift).  That will have the necessary plumbing to feed a bigger engine.  You may have to open the jets up some, but it should work.  Also will work when u want to heat the fuel. I think the best is to use ethanol, you would only have to heat it to 173 deg. F and inject the vaporized fuel using the propane style carb.  PLus the ethanol is pure without additives, not to mention might actually be cheaper then gas!  Then crank up the compression ratio!!!!  18 to 1 is best.
Mark
dirt diggler
Quote from: Mark69 on July 22, 2008, 01:07:30 PM
Mark
Hi Mark,
The way this works is that we don't use any jets.  The carb could be completely removed, the only thing required is the butterfly.  In fact that may be exactly what happens on the V8 we are working on.  A simple flaper to retrict air flow is all that is needed.
Because the fuel vapor is already mixed with the air before the carb, none of the fuel metering is needed, only a way to change air flow to the engine.
ciao,  Dirt
allcanadian
@dirt digger
QuoteWe ran across a you tube vid of a guy running a generator on fuel vapor, by sucking the inducton air through liquid fuel, then to the carb.
We did the same thing, using an 11HP, briggs & stratton, riding lawnmower.
Was the engine under load at half throttle when you did the test or was it freewheeling?
Good job ;D
