Thanks to ALL for your help!!
Ronald Brandt 1983 Converter
Started by dani1, July 21, 2008, 05:50:32 PM
dani1
Hello all,
Did someone here build this converter from http://www.icehouse.net/john1/tesla.html ? I want to test this with Ni-CD to power a laptop. Has someone specifications for S1-S6, the used diodes and the osc. here?
Thanks (and good luck)
Thaelin
   Check out ash over at panacea, he is in the test phase right now. Posting on EVGRAY
but not sure if he is here as well.
   My setup, manually switched did extend the run time but still did run down. Used 5 amp
batts and was drawing 1.5 amps which did run much longer than if I just did a direct hook
of all 4 in parallel.
thaelin
Paul-R
cosmo1979
i have built 3 to date  2nd one worked the best with mechanical commutator and relays   solid state one seems to run batteries down unequal.  in route to building a larger one and fitt it to an electric golf cart    to see if it will work
DeanChristin
Is it easy for for you to work on this? How will you manage to work with mechanical commutator?
achat appartement neuf
