New Newman Motor Replication
Started by Careica, July 22, 2008, 02:38:10 AM
hartiberlin
Quote from: onlov on July 31, 2008, 08:00:19 AM
Stefan are told, if scope is grounded, back current spikes disappears.
No,
my scope were always grounded and you still can see the
spikes as I showed in my scope shots.
Also I verified, that there was a big current spike,
as I put 2 graphite brushes very near into water and when the commutator
switched I got an arc under water.
This proves, that there is a back current spike.
Onlov,your negativity gets annoying.
I would suggest shut up until you have built yourself a machine.
Regards, Stefan-
Careica
Quote from: hartiberlin on July 31, 2008, 05:16:19 PM
No,
Regards, Stefan-
Stefan, about coil size. So I did not get understanding. Will I wound coil to get 250 Ohms or will I wind whole 1kg 0,2mm bobin in my motor and get near 2kOhms. Why some guys say "more tiny coil is better"? Which way I choice? Wind whole bobin (2kOhm) or just to get 250 Ohms?
bogchiblaster
Hi guys!
Small question here... do I need to have a very powerful magnet to run the newman motor?
I found some magnets from old speakers here. Do you think that will be enough? I do not have neo magnets
Also, theoretically speaking, can I power a 2Kilowatt home with this motor? How much equipment will I need?
(eg. copper wires, magnets, etc.) ;D
thanks!
onlov
No,
Regards, Stefan-
Stefan, you are little bit dishonest. You are saying in many many threads, if Newman machine or scope are grounded you cannot see back current spikes.
I find in couple minutes two:
http://www.overunity.com/index.php/topic,2510.msg36522.html#msg36522
QuoteHmm,
what shunt did you use to take the input current scope shot ?
Is the scope grounded ?
Please remove the grounding.
http://www.overunity.com/index.php/topic,2510.msg35138.html#msg35138
QuoteP.S. The grounding is only related to the scope ground,
if you want to take scope measurements.
Otherwise don?t ground the Newman machine as this
will short out the RF bursts to ground, so the RF power
is lost..
I am quite sure Your "back current spikes" are only measuring error. I have asked your measuring circuit. You want not get it. It seems to be, Your overunity talking is only a big cheat. Your pages and advertisement on it is your business and it's necessary to talk nonsenses to forums readers...  :(
Why You don't measure over plasma spark with scope and prove features of your "plasma battery"?
It's also necessary to measure your back current spikes when motor is loaded...
http://www.overunity.com/index.php/topic,1628.msg15353.html#msg15353
QuoteYes, in some test it was producing around 135 % efiiciency. But the main output is in the RF burst and it is hard to capture and convert. I will try to use the new principle from the Steven Mark thread to see if it can be used by coupling it to a 90 degree coil wound around it...
So, your "overunity" features are totally useless!
onlov
Quote from: bogchiblaster on August 01, 2008, 02:45:08 AM
Hi guys!
thanks!
Neo magnets are better, but it's important, at magnet poles turn as close as possible at inner surface of the coil.  Strongest field is close of poles.
two 2D-simulation.
Red color means strongest field.
correct length
http://www.aijaa.com/img/b/00992/2400441.gif
Too short magnet
http://www.aijaa.com/img/b/00887/2400431.gif
Maybe best shape for magnet. it's build many magnets with different size.
http://www.aijaa.com/img/b/00968/2395081.gif
If you ask Mr Stefan Hartmann, you can get much more than 2kW electric power. But I think Newman machine is "underunity" device! You can get little bit less as you put in... :(
