New Newman Motor Replication
Started by Careica, July 22, 2008, 02:38:10 AM
onlov
Quote from: hartiberlin on August 01, 2008, 08:35:03 PM
All,
please ignore user:
onlov
He is twisting the facts and is not reading.
Thanks.
Sorry but Herr Stefan Hartman itself are liar and dishonest.
Please, read this link and you see part of his lies!  :(
http://www.overunity.com/index.php/topic,5215.msg117675.html#msg117675
Careica
Quote from: hartiberlin on August 01, 2008, 08:45:18 PM
If you use the whole bobin ( 2 KOhm) you need to
have a higher supply voltage, which is okay.
You need to get around 2 to 5 mA current draw, when the motor is running
at full speed.
The more copper the better.
Use the most copper wire you can afford ( many turns of coil is import !)
and then use the right supply voltage by putting NiMH 9 Volts batteries in series
or better or bigger motors 12 Volts  lead acid cells in series.
So if you have 2 KOhm wire DC resistance you need for 50 mA
constant current without the commutator:
0.05 A x 2000 Ohm= 100 Volts supply voltage.
So if you use 2000 Ohm coil resistance you must use about 100 Volts
( so about 11 to 12 x 9 Volts NiMH cells in series)
and then with the commutator switches the input current will
go down to around 2 to 5 mA.
So if you want to have a safer suppy voltage, you need to get bigger wire
diameter to have the same number of wire turns for the coil and
then have a lower DC resistannce for the coil.
Would be good to have at least 10 Kg copper wire, so you have
enough turns of copper wire.
Hope this helps.
If you want to save money and use lesscopper, use my idea with the 5 LC tanks in series.
Regards, Stefan.
And if I use 200-250 Ohms coil will it work whit 12V L-A Battery? And what I understand that 9 V NiMH will not show "recharge" effect. I mean, if I start testing whit that 9V battery, his voltage would be let say 8,5V and then I run this motor for couple days, then measure voltages again, it will only drop, because it will not be able to take charge?
But will it still make OU-effect if I use 0,2mm wire and 200-250Ohms? I have countet, that in my bobin 1g = 3,6 meters. And 360 meters give me near 200Ohms, so it will be 100g of wire until I get near 200 Ohms, but that is small amount is it?
And what you think about that, if I use about 150g of wire for "motor coil" and rest of the wire I could wind too, but it could be like generator coil. What you think?
hartiberlin
Quote from: onlov on August 02, 2008, 02:11:30 AM
First learn english language, when you try to post name callings...
onlov
Quote from: hartiberlin on August 01, 2008, 08:50:25 PM
Still one example:
If you use a charge on the NiMH batteries for my upcoming scooter,
for instance I charge them up with
100 Watthours of energy and
normally the electroscooter will
only go 20 Miles with this energy charge on the batteries.
Then I will use the modified Newman motor
on the electroscooter and again I charge up the empty batteries
with 100 Watthours and then run the scooter with the modified
motor and I will get 150 Miles with the same driving habit and speed until the batteries are empty...
So that is, what I call  usefull overunity....
Maybe the batteries will even last for more miles.
We will see.
It's only nonsenses talk without proving. If Newman motors has efficiency 150/20 = 750% better as coventional motor, Newman will become a rich man. But all of this is talking of nonsenses without any kind of proves. With similar wishful thinking cows will be fly...  ;D
onlov
Quote from: hartiberlin on August 02, 2008, 03:56:03 AM
Yes, my english is bad. But I see, you understand me perfectly!
Maybe much worse thing is, you are studying at university of Berlin, but still you talk nonsenses of OU. :(
Herr Hartmann, Ich bin auch deutch in die schule gelesen, aber ich habe beinahe alles vergessen.
