breakthrough in the field of clean power generation
Started by tulook, July 22, 2008, 09:21:02 PM
tulook
Posted: Sun Mar 02, 2008 3:26 am Post subject: Pulsed Abnormal Glow Discharge Plasma Reply with quote
Paulo & Alexandra CORREA
OP "junglelord"
PAGD (Pulsed Abnormal Glow Discharges)
Labofex ~ Experimental and Applied Plasma Physics ~ Press Release
Concord, Ontario, Canada, L4K 2J6
Fax: (905) 738-8427
Canadian Breakthrough in Power Generation
Non-Polluting Electrical Power from Pulsed Cold Plasmas Delivers More Power than it Consumes
Prepares for Manufacturing Development
Fully Protected by Recently granted American, British, and Israeli Patents
Dr. Paulo Correa, M.Sc., Ph.D., Partner and Director of Research at Labofex- Experimental and Applied Plasma Physics of Concord, Ontario and Partner Alexandra Correa, (Hon) BA are today announcing a significant breakthrough in the field of clean power generation. The technical basis for the extraction process has been a carefully guarded secret until full disclosure was secured through the granting of three US patents: US Patent #'s 5,416,391, issued on May 16, 1995 and entitled "Electromechanical Transduction of Plasma Pulses"; 5,449,989, issued September 12, 1995, entitled "Energy Conversion System" and 5,502,354, issued on March 26, 1996, entitled "Direct Current Energized Pulse Generator Utilizing Autogenous Cyclical Pulsed Abnormal Glow Discharges". The Correa grid-independent Energy Conversion System utilizes an energy reactor whose function is based upon heretofore unknown spontaneous emission properties of certain metals in vacuum and involves an anomalous cathode reaction force conforming to Dr. H. Aspden's Law of Electrodynamics. The associated Motor Drive provides for direct electromechanical transformation of the energy accumulated within the reactor. The reactor may be conceived of as a portable vacuum battery made active only when needed. The Correa technology employs cold-cathode vacuum discharge plasma reactors to set up self-exciting oscillations, in the form of pulsed abnormal glow discharges triggered by auto-electronic emissions, in order to produce power. The circuit is driven from a direct current source of impedance sufficient to prevent establishment of a sustained vacuum arc discharge. In combination with a special circuit, electrical power, in excess of the input power needed for operation, can be extracted. The System, therefore, may also be referred to as an over-unity system: where net energy output greatly exceeds net energy input. Unlike the cold fusion process, which claims to output low grade heat, the Correa technology directly generates electricity at power voltage levels, without any utilization of cold or thermonuclear fusion principles. Another important feature of the apparatus is that it employs no radioactive compounds and generates no nuclear radiation or radioisotopes. The energy system is entirely pollution-free, self-contained and composed of readily recyclable materials. Storage of the power produced may be carried out by traditional means, be these mechanical or electrical.
Energy conversion system applications for electric vehicles, stand-alone power supplies and autonomous housing are currently under development. The inventors hope that by making vehicles self-sufficient in terms of energy, this technology will offer the possibility of bypassing massive infrastructure expansions in order to make the electric vehicle a feasible reality while solving the problem of range which currently detracts from its appeal. Other potential applications include- pulsed lasers, inverters, transformer and motor circuits. The inventors are presently engaged in negotiating licensing agreements with a view to development of the applications.
Contact: Dr. Paulo Correa, Research Director
FAX: (905) 738-8427
z.monkey
Howdy Tulook,
Hey, this sounds exciting.  I get notions of Tesla when I read about this device.  What I picture in my mind is a vacuum arc tube with a coil wrapped around it.  Are there any physical specs, or details?  This sounds pretty close to what I had visualized as a Zero Point Energy Converter.
Blessed Be Brothers...
Goodwill to All, for All is One!
tulook
> In the 1940's, little work was done on the North-American continent on
> the presence of longitudinal forces in plasma discharges. The notable
> exceptions may have been the self-funded research of W. Reich and of
> T.H. Moray. Reich claimed to have discovered a spontaneous pulsatory
> activity of the space medium in cold cathode diodes sealed at high
> vacuum, and to have achieved oscillatory frequencies that reached 30
> Kc (4). He equally claimed to have designed a motor circuit driven by
> the cyclic discharge in question, but all the details of the circuits
> were kept secret by Reich, and have remained so since the burning and
> banning of his publications by the FDA in 1956. His suspicious death
> in prison followed shortly thereafter in 1957.
> 4. Reich, W (1949) "A motor force in Orgone energy: preliminary
> Anomalous cathode reaction forces varying in proportion to the square
> of the input current were first identified separately by Tanberg and
> Kobel, in 1930, during studies of cathode vaporization in "vacuum"-arc
> discharges (VADs) and stationary cathode spots (1,2). In his original
> paper, Tanberg made a case for the presence of longitudinal forces on
> electrodynamic interactions, which he attributed to the counterflow of
> vaporized cathode particles (1), but K. Compton demonstrated that the
> vapor jet only accounted for <2% of the reaction force's magnitude
> (3). He suggested a different interpretation of the the electrodynamic
> anomaly, arguing for a mechanical rebound, at the cathode, of
> charge-neutralized gas ions that hit the cathode in the course of the
> discharge (bombardment rebound) (3).
You know cathode ray tube tech has been around like forever, since it appears that that you can get more power out than in the PTB have the same problem they had in the past. Just don't irradiate your self while fooling around with this thing....see link
http://www.patentstorm.us/patents/5416391/claims.html
