Mysterious Resonant Circuit
Started by EMdevices, July 24, 2008, 10:04:51 PM
EMdevices
Hi guys,
@Stefan,  it works at a particular frequency, but it can work at other nearby frequencies.  I just say it works at a particular fixed frequency because it's a tuned device and only when tuned can I cancel the RF at the battery so I can take a clean amperage and voltage reading.    If it's not filtered it might still be OU but I don't have the patience to integrate these frequencies to find out.   Also,  I realized I made a mistake in the circuit.  Below is the correct one.   Notice the battery connects differently.    The first LC branch is what DID THE TRICK   :)     this LC branch somehow provides the reactance and saves the battery from doing it, or sourcing reactive energy, or it just shorts RF, simpler concept.     The second branch is just extra for a little bit more smoothing so I can have a clean amperage reading.
@Peterae,  yes, a simple capacitor across the battery will not short out the RF, which I found distrubing, because a capacitor has a low impedance at high frequencies,  however, most capacitors have other parasitics and series resistance (Effective Series Resistance, ESR)  or maybe for some other reason just don't do the job.   An LC branch, on the other hand, I found it works miracles, it surprised me how well it worked !
@ BEP, you're correct, we're shorting with the first LC branch, but the last branch is blocking as per figure below and since I used a mini toroid ferrite, I'm smoothing the current so I have a nice clean amperage reading.  without this second branch the voltage is just as smooth, maybe the ripple 24% bigger, but I just wanted to be absolutely sure the current wasn't surging.
@ whoever asked,  the frequncy is around 10 - 25 MHz or so,  the scope shots are at 20 ns per division, this just going from memory.  I live close to Cape Canaveral, Florida , so lot's of radio stations around here.
EM
P.S.   I have found an article that might be the single best theory to describe the SM tpu.  It talks about rotating magnetic fields,  magnetostriciton,  rotation, NMR, and even LEVITATION in an Iron Nickel (FeNi) wire. They even talk about frequencies in the low kHz.  It's from IEEE, and it's about 190 kB file, so I can't uploaded.  [edit:]  Ok I just figured out how to upload:  see the file here:  http://www.overunity.com/index.php?action=tpmod;dl=item102
I added a before/after comparison of voltage at the battery terminals, the LC branch sure works wonders !!
AhuraMazda
@EM
The IEEE article is great. Can any one with access post the other articles which are in the reference sections?
Frederic2k1
It would be very interesting to know, if your circuit have OU results in a faraday cage. Do you plan to do such a test ?
Thank you
aleks
Quote from: EMdevices on July 29, 2008, 02:16:03 PM
Cool, thanks for the paper.. If they had 528 Hz, it would fit into Solfeggio's "transformation and miracles" frequency. But probably it's still the same thing (10 Hz is a small deviation). I wonder if Solfeggio's original frequencies shifted now. Earth grows, frequencies shift. Maybe current MI frequency should be as in this paper - around 538 Hz? :) Well, it's just a speculation.
Also note that wire's peak rotation frequency lies in "Schumann resonance" range pretty much.
And... as article suggests, there is really no difference between solenoid and acoustic transducer as far as these effects are considered. So, it's about interatomic forces non-equilibrium induced by mechanical vibration. In this TPU biz, magnetostriction is of course a thing to use since it allows to couple to electric circuitry easily. But you surely should not stick to "magnetostriction" term in understanding how thing may work.
Peterae
Ok i have taken all the scope shots of my setup, can someone explain how i post 4 scope shots and a picture of my setup
Thanks
Peter
