Thanks to ALL for your help!!
Firestorm replications
Started by maybeHHO, July 31, 2008, 02:36:12 PM
NerzhDishual
Hi blokes,
These French guys are also drilling some holes in the spark plugs!
http://www.c2bs-bougies.com/page/bienvenue.htm
(In French)
They were granted a patent: WO2006061468A1
"DEVICE FOR IMPROVING THE PERFORMANCE OF A SPARK PLUG
FOR A TWO OR FOUR STROKE INTERNAL COMBUSTION"
The patent is in French but not the "pictures"... :)
You can find it here: http://freenrg.info/Patents/Firestorm_Like/
Best
Nolite mittere margaritas ante porcos.
Bruce_TPU
Quote from: maybeHHO on August 01, 2008, 05:53:02 PM
Thats odd because I just heard a blog talk radio interview with the creator, Rober Krupa. At the time of the interview, he is saying that he still plans on making them. In fact he was on his way to Brazil because their government has shown interest in them.
Listen for yourself http://www.blogtalkradio.com/kywaterfuelmuseum/2008/06/02/robert-krupa
and maybe your "friend" needs to give you better information. The plugs were designed in a basement using old plugs, not some space age metals. The video Posted clearly shows a replication and it working. I didn't say anything about MIB.
why is everyone so hostile about the firestorm plug? bitches
@maybeHHO
I did NOT say that YOU said anything about the MIB.  I made that comment simply because it seems that anytime something does not make it to market, that become the "lore".  Please re read my post.  Nor did I say anything about "space age" metals.  I said the plug had/has expensive metals in it and would be next to impossible to duplicate.  My friend worked up the CAD drawing for the original firestorm plug.  Or do you think that perhaps no drawings were needed for manufacture?  ;)
Lastly, I was not hostile about the firestorm plug, just stating what I know about it.  And because my friend personally knows and had worked with Krupa, it is much more than others here.  You can build what you want or wait for the re manufacture from "Brazil".  lol  It makes me no mind whatsoever.
You asked if anyone knew more about the firestorm plug and I told you what I know.  The member here who did the work was JDO300, one of the most respected members of the forum.  So, because you didn't like the information, you call us "bitches?"
You can take your firestorm plug, sit on it, rotate and ignite... Then you can feel the firestorm first hand....  ;) :D ;D
Another waste of my time.
