new tri-gate configuration
Started by gwhy!, July 31, 2008, 08:54:51 PM
exxcomm0n
@ gwhy
You MIGHT be able to fudge on the horseshoe mags with hard drive mags.
I've had this idea for a while (and it seems Rusty has too, 'cept he's using HS mags ;) ) as it's harder to come by horseshoe mags these days.
(I  _think_  I've seen  _1_ vendor offering horseshoe neos [supermagnetman.net who gives better volume discounts than magnets4less, but I haven't researched the shipping differences].)
From the ones I have here it seems the polarity has a unique arrangement as the sides of the mag are the opposite polarity of that on the face e.g.:
         TOP  (FLAT)                              SIDE (EDGE)
        XXXX          N                            X        S
          XXXX        N                            X        S
             XXXX     N                            X        S
               XXXX    -                            X         -
               XXXX    -                            X         -
              XXXX     S                           X         N
           XXXX        S                           X         N
         XXXX          S                           X         N
....although, I have found a few that seem to be.......
        XXXX          N                           X        S
          XXXX        n                            X        S
             XXXX     s                            X        S
               XXXX   S                            X        -
               XXXX   S                            X        -
              XXXX    s                             X       N
           XXXX       n                             X       N
         XXXX         N                            X        N
Which is really confusing as I'm used to mags having diametrically opposed polarities.
So maybe stacked HD mags to get a greater area edge effect ?
This is not something that'll be that easy as the epoxy used to hold the HD mags to the metal backing for mounting in the HD is not that easy to break.
I've found (this has worked for me with 80/20% success rate) that you can use a guitar string (G (unwound), B, or high E) as a rope saw if you can get it between the metal mount and the mag to defeat the epoxy.
A question I have about your trigate/MkE-oneway marriage is, does the MkE have to have such sharp right angles?
Could a slope (before the crucial 2/3's point of the MkE) marry the MkE field to the trigate field and allow each (MkE slope) start to have the acceleration effect restart at each MkE beginning to negate the "wall"?
Have you set up multiple arrangements of these end to end to see if that is possible and you can create a loop without turning the arrays into a large multi-piece ring mag?
Like this:
T = trigate
M = MkE
T  T  T  T       MMMMM      T  T  T  T       MMMMM       T  T  T  T       MMMMM       T  T  T  T      MMMM
                M                                     M                                      M                                     M
        M M                                 M  M                                  M  M                                M  M
........so instead of the MkE array being formed thus:
                                                             __________
                                            __________
.......it is formed like this?
                                                             ___________
                                  ________
That way it is covering the same area, but the 1/2 way point is still (marginally) allowing the roller into the trigate with its accumulated acceleration?
Just questions and wool-gathering dude. ;)
I do have to give you major kudos, as in another thread we've both participated in, array use seems chained to 2D thinking, whereas you've broken out of that mold and started thinking 3D which seems to be (the more I play with this stuff) the best way to think about array usage.
I'll be posting more of my recent failures over there shortly, and invite you to take a look as my failure MIGHT show you something it didn't show me and lead to your success.
;D
P.S.   I just (finally) watched the vid you posted and I was wondering had you tried the roller without the BBs on the end yet?
Was the behavior any different?
Have you considered slotting a piece of plexi or other plastic to allow it to be sloped or form the MkE more uniformly?
What happens when you have the MkE formed as you do, but there is no receiving trigate on the end?
When I stop learning, plant me.
I'm already of less use than a tree.
gwhy!
Quote from: exxcomm0n on August 13, 2008, 10:17:10 AM
@ gwhy
        XXXX          N                            X        S
          XXXX        N                            X        S
             XXXX     N                            X        S
               XXXX    -                            X         -
               XXXX    -                            X         -
              XXXX     S                           X         N
           XXXX        S                           X         N
         XXXX          S                           X         N
        XXXX          N                           X        S
          XXXX        n                            X        S
             XXXX     s                            X        S
               XXXX   S                            X        -
               XXXX   S                            X        -
              XXXX    s                             X       N
           XXXX       n                             X       N
         XXXX         N                            X        N
Like this:
T = trigate
M = MkE
                M                                     M                                      M                                     M
        M M                                 M  M                                  M  M                                M  M
                                                             __________
                                            __________
                                                             ___________
                                  ________
;D
Thanks Exx for the heads up about HDD mags ( I got boat loads of them ) I will have ago at getting some of them off the metal they are stuck to.
The step in the MkE array can be sloped and should not be a problem the important thing I have noticed is the distance under the trigate needs to be right to get maximum efficiency i.e to small and the roller will not continue into the trigates to big a gap then roller refuses to even enter the first trigate.
I haven't setup multiple arrangements of these end to end as of yet but well worth having ago ( I'm not sure how well the end of a trigate array will marry into the start of a MkE array ) because as you have seen in one of my vids the roller do not get thrown clear of the pull back from the tri-gate array when rolling along a level plain ( its close, but not close enough. maybe a bit more tweeking ) so the fields would have to overlap. I have sort of been side tracked with the seasaw effect I shown in my last vid that will over come this problem of overlapping fields.
The BB's are mainly there to give the roller mag a big more weight and stop it flipping around so easily, but they do also help a little when going through the tri-gate array.
If you make the MkE array to much of a gentel slope there isn't enough momentum to break though the magnet that is connecting ( shorting )the first two trigates together.
If you have no receiving tri-gate the MkE act just like it would normally i.e the roller will go backwards and forwards over the array until it stops in the middle part of the array that is closest to the roller ( if you know what I mean ).
I will look forward to seeing any vids that show anything intresting positive or negative cos its all good and something that peeps can learn from.
Cheers.
gwhy!
@all
   Just had another play with what I call the Kgate. I didn't vid anything dint think there was much point at the mo but some info for exx and anyone else thats intrested:
On a level plain the roller do not quite get thrown clear of the last tri-gate as I said before ( its very close ) but what I did do was to put another MkE array about the same length as the tri-gate array away from the  the last tgate and with very carefull placement ( distance ) the roller could be pulled free of the last tgate and into the MkE array  ;D . Some may say so what, but the cool thing was if you placed the roller at the very point it starts to get pulled into the MkE array and then remove the MkE array the roller do not get pulled back into the tgate Which may mean that there is something going on with the interacting fields ( on a positive side  ??? ). I need to get hold of a longer piece of plexi so I can see ( hope  ??? ) that 3 sets of Kgates will make the roller accelerate, that will be a step in the right direction.
P.S    just putting another tri-gate array at the end of the Kgate at the same distance was a non-starter the roller didn't get anywhere near the entrance to the second tri-gate array
4Tesla
Quote from: gwhy! on August 13, 2008, 04:28:06 PM
@all
I like to see video when you have a chance.
Thanks,
Jason
