YouTube Motor Video
Started by 4Tesla, August 01, 2008, 03:34:33 AM
CLaNZeR
Quote from: 4Tesla on August 01, 2008, 09:19:47 PM
@Sean
Wow!!  I like your site.. a lot of nice work!
Still waiting for the parts to finish your replica of the MPMM?
I pull it out every now and then and have a play. Final video is here I did for the Whipmag
http://uk.youtube.com/watch?v=EBE4MfSVTHE
I like the tri-gates!!
In the ramp video the magnet rolls off the ends of the ramp.. If you blocked the ends of the ramp, would gravity be enough to start it rolling the other way so it would roll back and forth continuously?  I think you have something there!  It seems that these gates could be used to spin a wheel also.. many ways to configure them.. very excited about the gates!
http://www.overunity.org.uk/tri-gate/CLaNZeRSTri-ForceGate13.wmv
Once again great work!
You need to turn the Roller around to get it to go the opposite way.
Loads of people played with the Tri-Gates and tried many things, so worth checking out the threads in these forums.
Cheers
Sean.
CLaNZeR
Quote from: 0c on August 01, 2008, 10:16:18 PM
You'll like it even more when he gets the forums fixed!  ;)
(Hi Sean  :-*)
;D ;D ;D
Hi mate  ::) hehe
CLaNZeR
Quote from: 4Tesla on August 02, 2008, 12:36:01 AM
Hi Sean and all,
I quickly made a rough graphic of a magnet motor using tri-gates.. it uses 12 gates..
What do you think?
Jason
Edit: Ignore the spoke lines and circles.. just used them for a reference to draw the gates.
Nice picture
Problem is as soon as you close the loop the Tri-Gates become one big magnet and you have no movement at all.
You need to have blocks of Tri-Gates that are spaced apart enough from each other, but then you hit sticky spots on entry rather than exit.
Keep playing though, as you may hit upon something.
Cheers
Sean.
4Tesla
Quote from: CLaNZeR on August 02, 2008, 06:39:39 AM
I'm green to magnetics.. I didn't know about the closed loop.. What if you put in a copper shield?  Would that break the loop?  There probably be a sticky point there, but the other magnet on the other side of the rotor might be able to pull it through?
What do you think?
Jason
4Tesla
Or if that doesn't break up the loop maybe three shields?
