Fueless Friction Heater Manufacturer Found
Started by Cap-Z-ro, August 01, 2008, 02:59:08 PM
Pirate88179
Cap:
I don't remember if you are in the US or Canada?  If in the US, most states have a statute of limitations on fraud which should be at least 2 years.  (It varies state to state.)  Of course, if you hire an attorney (or barrister?) it will cost more than you lost on the deal.  I just hate to see frauds like this get away with it.  I understand about being wiser though.  A financial guy I listen to here on the radio (Dave Ramsey) calls this "Stupid Tax", and I too have paid my fair share over the years.  But, I have also learned a lot as well.
It would cost a lot to machine something that large that is made round and true to precision tolerances but, you might look around and find something someone else has already paid to be made that way.  I can't think of anything off the top of my head, but I'll bet there is a canister or case made for another purpose that might fit your needs that might be cheap to acquire through salvage or surplus or recycling places.
A quick example would be a discarded lawn mower. (I know this won't work for your needs but it is an example)  If someone wanted to have a round, precision machined aluminum cylinder made, it would cost a lot to do.  A one cylinder lawn mower already has this and folks throw them out every day.  Just something to think about.  Take care.
Cap-Z-ro
I'm a Canuklehead Bill.
"Stupid tax"...guffaws. :)
Spinning metal is the way to go for accuracy...I'm not sure what size of aluminum canister are on the lawnmowers you speak of, but it would need to be about 24 inches wide X 27 inches high.
Regards...
helmut
@Cap-Z-ro
Thanks for the update. I am sorry, that it is a expensive experience for you.
I hope one day it will pay out for you. And in addition to that, we all listeners have learned via your report.
Many thanks for that too.
@Bill
I like the way like Bill is heating his home with lamps.
So i was searching after similar Lamps here in Germany. But there are not easy to find.
But i do not look after a oil lamp.
Because oil is expensive as Lamp oil or petroleum. It would be usefull to find a lamp,that workes with oil from plants.This one can buy cheep from a good equipped farmer.This kind ob oil needs mor oxygene to burn propperly.
As a matter to be developed,  is a process , to start this Lamps , the electric way. Because,then it might be possible to start the lamps via a timer .
It is not overunity, but very usefull .
helmut
Shanti
Quotewill be true and round for stable rotation @ 35000 RPM's.
Is this a typing error? I assume you mean 3'500 RPM and not 35'000 RPM.
Otherwise you could immediately forget your project to ever turn such a large thing as you mean at 35'000RPM...Believe me...
Sure this would theoretically be possible, but surely only with extremely professional equipment and undreamable expensive...Ask some Jet-Engine producers...
I don't know why just spinning one container in the other should produce OU. For as has been said before, otherwise it would make no sense to use this method of heating, one would just rather heat the water directly by placing wires in the water...just like air humidifiers do...100% efficient...Or even use a conventional Heat pump to get higher efficiences.
The reason, why I think this doesn't do anything is, as this method of the two containers spinning with an oil-film in between is widely used in industry: It's called a Hydrodynamic Bearing! Also all of the machines we produce have them. Also newer Hard-Disks use them, ...
And they never showed any OU effects...
But if you would construct the heater rather like Schauberger intended, e.g. with the spiral in it, etc. like someone here mentioned, this would be something else.
Or if it is made like the hydrosonic pumps of Hydro Dynamic Inc www.hydrodynamics.com.
Sure just my 2 cent
Cap-Z-ro
Yes that was a typo Shanti...an easy mistake for someone who is innumerate.
The RPM's are 3,500 and not 35,000.
Unless...I am building an antigravity machine, and mistakenly let the cat out the bag ? :)
I don't know why people mistakenly have the impression that this unit is supposed to be over unity.
The unit was never promoted as over unity or a free energy producer.
It is simply a fuelless heater...nothing more that an alternate heat source.
Hopefully the misconception is cleared up.
Regards...
