Tri-Gate Motor (TGM)
Started by 4Tesla, August 03, 2008, 05:08:36 AM
4Tesla
By gates are you talking about walls/stickies?
Thanks,
Jason
gwhy!
Quote from: 4Tesla on August 04, 2008, 01:26:20 PM
Thanks,
Jason
Hi Jason,
  Your gaphic shows that 1 arm will be going though each array while the other arm is jumping the gap which is a good start, but you will need at least 2 ( 3 would be better) arms going through the arrays for every 1 gap being jumped. unless your still going to try with shielding. Hope this makes sence. This is what nighlife has explained. I will see if I can work out a good way of showing you what we mean about the gap in a vid.
edit:     a gate is 1 tri-gate, an array is tri-gates connected together.
Cheers.
nightlife
Hi Jason,
Each array has it's "own stickie" points within but each array as a whole has a wall.
If you are planning on using shielding, you must note that shielding only bents the magnetic flux action and you will still have a equal pull and push.
Magnets have a equal strength from the center and you can not have one side stronger then the other. There is always a center to a magnetic field and when shielding is used, you are only moving the center of the magnetic field.
These next pictures should help explain better.
4Tesla
Thanks guys!!  I understand better.  I ordered some magnets to experiment with.. so that should help me understand better also.
4Tesla
I download the 30 day trial of Vizimag that Razz mentioned.. here are some graphics from playing with the program analyzing tri-gate arrays.
Jason
