BREAKING : **~Imhotep~**'s Free Energy Radiant Oscillator Lite
Started by Omega_0, August 03, 2008, 10:40:26 AM
z.monkey
Howdy Imhotep,
I noticed that you are using a relay and not power transistors.  Do you have an electrical reason for this?  I have had problems with power transistors myself.
Blessed Be Brothers...
Goodwill to All, for All is One!
robbie47
Quote from: z.monkey on August 05, 2008, 07:22:28 AM
Howdy Imhotep,
The reason can be found in the theory of the phenomena applied here:
Ucoil= L * dI/dt , where L is the coil value in Henries.
The faster you switch off the current in a coil the smaller dt and thus the higher dI/dt and thus the higher the voltage peak over the coil directly after switching of current.
In general relays switch off faster than power transistors.
An other reason could be the simplicity of this setup.
In this case the relay can be wired very simple to achieve self oscillation.
When power transistors would be used, there is also the need to drive that power transistor.
This complicates the circuit.
However, as I pointed out earlier, relays wear out quite fast in this application.
Let's see how this discussion thread develops....
robbie47
z.monkey
Howdy robbie47,
That makes sense.  That is where the FE is, in the release of the current in the coil.  When that voltage falls off slow there is less FE produced.  Thanks Man!
renaud67
Quote from: **~imhotep~** on August 05, 2008, 03:43:35 AM
the new movie is being uploaded now PLEASE WATCH!!!
Hello,
Sorry where the movie can be found ?
