5amp negative adjustable voltage regulator needed
Started by mostrander, August 03, 2008, 11:38:37 AM
mostrander
Hey guys I need some help finding a part for a power supply I?m building. The part is a 5amp negative adjustable voltage regulator -1.2v to -32v. I have found a 3 amp part# lm333 but I need a 5 amp, any suggestions?
insane4evr
You can connect several of them in parallel. Look at the datasheet from National Semiconductor (page 5).
Since this regulator is the linear family, you will need massive heatsink at high output current and high input-output differential voltage.
khabe
Quote from: insane4evr on August 03, 2008, 12:30:45 PM
Same opinion from my side,
I use parallel switch mode regulators often enough,
khabe
gyulasun
Quote from: mostrander on August 03, 2008, 11:38:37 AM
Hi,
The LM333 data sheet includes three LM333 devices in parallel to get 9A output current from -1.2V to -27V....   Is it not  enough good for you?
http://www.national.com/ds/LM/LM333.pdf
mostrander
