leedskalnin flywheel
Started by chevyiron420, August 04, 2008, 03:14:52 AM
rangerover444
This is another page w/ Ed?s wheel + home made model (unfinished).
http://www.leedskalnin.net/wheel.htm
Here are some speculation as for it?s purpose :
1. Generator.
2. Wave generator for different frequencies.
3. A motor that works on ground currents.
4. To produce a certain magnetic frequency that will vibrate the coral boulders
     atoms which will reduce their weight and rigidity.
5. Do the same, but this frequency would go through amplifier and translate to
     radio waves which will vibrate the rocks.
6. A motor / generator - OU machine.
In the same room, there many unexplained ?things? that does not make sense,
or at least not understood as to their purpose, some of them have to do with
the wheel.
Evidently he built a machine which did some work (so I believe), the configuration
of the wheel w/ all it?s surrounding ?sub-machines? and objects strangely put together,
is the only clue that he knew something we don?t understand.  Though it?s only
Assumption, still it?s hard to dismiss.
Beside the wheel there are many weird things scattered around Coral Castle :
If the wheel was an isolated case, it would be easy to ignore, but the whole place looks
like a museum of universal laws?.
Cheers
chevyiron420
when i first looked at the pictures of the wheel i never imagined that the magnets were shaped like that. i have never seen v shaped magnets before and i think it means something. i wonder if he made them himself, and they had to be that way to get a desired effect. i wonder what materiel they are made from and how one would wind them with wire to magnetize them.-phil
rangerover444
 These magnets where taken from a Ford Model-T flywheel :
http://www.leedskalnin.net/wheel-11.htm
Most likely he strengthen them (re-magnetized).
No one who visits Coral Castle so far could detect if the V-magnets are set
as  NN/SS/NN/SS/NN (which is the setting for an average electric motor), or
if it?s SN/SN/SN/SN, which ?never heard of? setting.  Since I have this model
at home I can tell you that just do it with a compass is difficult, since the v-shapes
are touching each other and the compass get confused.
However, if it?s really SN/SN/SN then the investigation should take a completely
different rout.  That means you have a constant circulation of magnets around the
wheel, without you doing nothing (North pole individual magnets stream run in the
opposite direction of S pole individual magnets stream). And this is a complete
different animal then we use to see.
In fact most visitors and even researchers that go to Coral Castle, do not know
exactly what to look at and where to start. It?s like to board a ship in order to
figure out how it works and made of, using a ruler?  Some basic knowledge
of Ed?s notes could help. And the wheel is one of those things.
* Just a weird thing about today?s magnets : you can get almost any shape magnet
(ball, bar, ring, plate, custom made, etc.) on the net that made of different materials
(Neodymium-Boron, Alnico, Barium Ferrite, Ceramic, Iron Ferrite, etc.),
but it?s close to impossible to get a large or a strong U-shape
magnet (let alone V-shape one)?for some unknown reason?
Cheers
**~imhotep~**
i have studied ed's work for a while . i live not to far away from cc and hope to do more hands on research of this forgotten genius.he states our measurements of electricity misses half of the story. he might be right. his flywheel (perpetual motion generator ) has been written about and a researcher in Florida has stated once he spun it up it would continue until he shorted out two of the adjacent magnetic clusters .
i believe the reference was in "Waiting For Agnes" all in all this mans work would be very fascinating to study more and i hope to get the chance to solve some of his mysteries  glad to see this thread !! ;D
**~imhotep~**
thank you rangerover4 great pix ,i wondered how ed got his hv ,now that mystery is solved !!
