Only Voltage? and capacitors
Started by Magnethos, August 08, 2008, 10:53:08 AM
Magnethos
I have seen a video where a guy can load a capacitor with only voltage and no amperes.
That seems to be impossible, but they guy can load it!
The, the guy discharge the capacitor and I can see the spark.
My question are...
1. If I have a 1Farade capacitor... how much time can I supply energy to a 20 Watt Device?
2. We need to apply volts and amperes to load a capacitor? Right?
If the guy is able to load a capacitor with only voltage and without using amperes... can free energy be possible?
gyulasun
1)  If you have a 1F capacitor charged up for ,say, 10V then the stored energy in it is: E= (C*V*V)/2  hence 1*10*10/2=50 Joule     i.e. 50Wsec    this means your 20W device is able to run from it for  50/20=2.5 seconds.
(Note: So you have to start in practice with higher capacitor value and or voltage and also use an efficient switched mode power supply to keep a stabil output voltage from the ever decreasing capacitor voltage.)
2) Yes.
Can give a link to the video you referred to?
Magnethos
@gyulasun
Here you have:
http://www.youtube.com/watch?v=fqa6JmxSmkA
I think that if the guy is able to charge the capacitor using only voltage (impossible in theory) we can recharge a capacitor infinite times because if we use only voltage (and no amperes), the battery will always has energy.
Could be correct my theory?
gyulasun
Thanks for the link.
It would be good to see the method in a schematics how he step-charges up the capacitor.  If he has to use a source from outside of his circuit (so it is not the circuit which produces the energy needed for the recharge),  then his setup is not overunity.
It is not true that capacitor does not need input energy for charging it up.  I recall Bearden referred to a scientific paper on step-charging a capacitor and there is an anomaly in the energy balance but I have not read that paper.
You would be right with your theory: if a capacitor would not need a charging current but voltage i.e. no input power would be involved, then you would have a 'perpetual' or at least a very long lasting energy source...
You happen to have any more info or schematics on this?
rgds,  Gyula
Magnethos
@gyulasun
Thanks for the info my friend
No, at the moment I haven't more info about the video. A friend is trying to contact the guy and ask for the schematics. If we have a reply from the guy, I will say you.
