How testatika can produce 3 kW running at low rpm?
Started by Magnethos, August 09, 2008, 04:49:08 AM
Magnethos
I have heard that testatika motor can supply 3kW, but as you can see... the testatika motor runs at very low rpm.
It uses a stator and a rotor like the windmills? or how it produces the energy?
Steven Dufresne
Magnethos,
One theory is that the disks are there just to act as a variable dielectric in a variable capacitor and that the source of the high voltage is something else. This means that the high voltage DC is supplied by something else (e.g.s: the magnets, the small cans) while the disks and the parts that face it, what Paul Baumann refers to as the antenna keys, supply smaller AC. When you combine the two you would end up with DC with AC riding on top of it being used by the pots. In that case there's no mystery to the disks running slow since in that case they would not be the source of the energy, just the source of some necessary AC.
Just to give one highly theoretical example... The whole thing is started by turning the disks by hand. Immediately you have AC at the antenna keys (the parts facing the disks.) This AC is small at first. If this AC is too small then we can guess that the darker disk is made of some material like vinyl which can be charged by rubbing it. In that case the AC would be larger. I know this from experiment. This AC would be used to stimulate the crystals in the smaller cans and in the two tall ones at the back. This crystals would then give off beta particles (high energy electrons.) That's the energy you've just tapped into. The result is a high voltage with a lot of charge. We need to reduce that voltage for useful output. That's where the pots might come in. The inner spiral and the outer perforated cylinder would act as two plates of a leaky capacitor. In the case of the 3kW machine, the inner spiral would be the leaky part since it's electrically connected to the two small, crystal-containing cans in front of the disks, the source of those energetic eletrons. Through arcing and corona over many stages, the charge would make it's way from the inner spiral, through various meshes and perforated metal to the outputs at the tops of the pots, the HV being lowered in the process. The reason for the AC from the disks was to provide a little back and forth movement to the charges as it moved through the interior of the pots to keep the path from being too conductive.
All the above was just to point out that the disks could play only a small part, providing just an AC signal. The reason for the slow speed is that the AC signal has to be of relatively low frequency.
-Steve
http://rimstar.org
He who smiles at lofty schemes, stems the tied of broken dreams. - Roger Hodgson
Magnethos
Thank you very much for the info Steven.
I thought that the source of energy was the disk, and not, as you say the disk only provides help to supply a small amount of AC. The high voltage DC comes from the (magnets?,small can? or something else). Then the AC would be use to to stimulate the crystals and obtain beta particles that supply high voltage. Then the voltage is converted into usable voltage.
So... they key to obtain energy is to stimulate the crystals?
I read that the crystals were Mountain radioactive Crystals or something similar.
I asked to you that because I have a possible schematic to build an Infinite Voltage supply and then I can increase the voltage with a voltage multiplier circuit. But... I think that the crystals are very hard to find.
Steven Dufresne
Quote from: Magnethos on August 10, 2008, 09:25:09 AM
Remember, it's all just theory. The one I gave was just one theory. The source of energy could very well be the disk. The Methernithan community isn't telling anyone how it works.
-Steve
http://rimstar.orrg
Magnethos
Quote from: Steven Dufresne on August 10, 2008, 01:02:13 PM
-Steve
http://rimstar.orrg
So... it will be difficult to understand how testatika works. I don't know why people make some big inventions and then hide the information.
Are we damned to a generation of lost inventions?
