Squared Newman motor, Can it works?
Started by Magnethos, August 09, 2008, 05:57:50 AM
onlov
David Wells Weather Control System is bullshit, but his motor construction is quite good and simple.
http://peswiki.com/index.php/Directory:David_Wells_Weather_Control_System
Coil has ferrite or iron core and magnet are cheap speaker magnet with iron poles. Firing seems to be with transistor. Operational principle of motor same as in Bedini or Lutec motor...
khabe
Michelinho,
Are you trying to teach papa how to make childs ? ::)
In principle near all electric machines could be expanded upon as Newman?s motor  :o
In reality it is quite the contrary  :'(
Any upgrading of Newma?s motor makes it more close to true machine.
Hereby 8 pole / 8 coil-pairs / axial / air-gap / one phase machine,
Making this kind coils is not too hard for owners of common sense, fecund imagination will help  8)
I hope you are able to understand about polarity of each coil  :-[
Series connecting is simple, when parallel then you have to know a bit more about motor theory ...
This unit will be much more effiecient when on to both sides added back iron  ;)
cheers,
khabe
khabe
when two-side rotating back-irons then test version looks like :o
Magnets as thick as possible, coils as thin as possible, air-gap(s) ...1.0 mm,
Coils thickness (one side) maximum 1/2 thickness of magnets (when Neodymium magnets)
Coils are pressed and epoxy impregnated ... different ways how to fix to outer frame ...
regards,
khabe
Magnethos
@ all
Thanks for the info, it's very interesting
Quote from: onlov on August 10, 2008, 01:11:57 AM
I met David Wells some time ago...
Do you say thet is bullshit? I have speak few about that with Mr Wells
Magnethos
Quote from: khabe on August 10, 2008, 05:05:00 AM
regards,
khabe
This design seems to be Very Very interesting... thanks man. I was searching to make a device with the best thing of newman and bedini.
Run on voltage and thinner shape. I have a device that can supply a good amount of volts from the air to the newman engine.
