Thanks to ALL for your help!!
Free energy collapsed feild concept.
Started by seekingknowledge, August 09, 2008, 11:46:20 PM
seekingknowledge
No onlov i didnt mean each of the batteries would draw 10 lilliamps of each idividual i ment they draw that of the hole lot together.
Stefan what do you think.
Michelinho
Hi,
I will only comment on the Newman design in relation with collapsing fields. The coil is not designed for radient energy collection.
First, in Newman's design, bifilar coil is not used. Why? He din't bother on the 55 miles long winding or wasn't aware of their properties.
The BEMF are spent creating a strong but limited in duration magnetic push on the rotor. The little leftovers are feed back to the source.
He shorts the coil after the BEMF is spent, closing the door to anything that could be available. Then the cycle starts over again.
Take care,
Michel
onlov
Michelinho:
QuoteHe shorts the coil after the BEMF is spent, closing the door to anything that could be available. Then the cycle starts over again.
Shorting the coil means that:
Motor acts as generator and brakes running speed. Because the coil is in short circuit, running magnet induces big current to the coil and it means heavy brake effect.
Michelinho
Hi onlov,
That is also true onlov. The short sequence is so short in reality that the back emf have time to give more push than brake.
The short section is used to restore the coils to neutrality just before reapplying the source.
It is a wonderful design but with very few specific applications and overunity or free energy are not its forte.
Take care,
Michel
