Thanks to ALL for your help!!
Steven Mark's TPU "No Battery" Startup Current?
Started by sirmikey1, August 10, 2008, 05:25:24 PM
sirmikey1
Hello people,
   I stumbled across a youtube video yesterday which
appears to use the same startup method as Steven Mark,
where you drop a magnet into a coil (generator).  Well, it
dawned on me that the current generated could be put through
a self-oscillating circuit in order to achieve self-running surge
overunity like so many others are doing.
SM
sirmikey1
 I am wondering if these magnets vibrate violently, self oscillate,
thus generate current? Has anyone figured out this part of the device?
sirmikey1
This video he has the startup generator magnet
vibrating slowly, but Steven Mark's claims to be
6000 cycles per second.  Would 6000 keep the
magnet closer to center?  Anyone tried this?
http://www.youtube.com/watch?v=anYxNitcrm0
MIke
sirmikey1
Hello people,
   I spoke with Gil about his youtube video on pulsing oscillationg coil/magnet,
asking that the add another coil as generator; and then to play with the frequencies
and see what happens with volts and amps.
Language barrier, and so I hope that everything is clear.
Here is a better video of his oscillating magnet/coil device:
http://www.youtube.com/watch?v=YMCk8zBE-4U
Mike
Magnethos
Well, first of all I don't know how Steven Mark's TPU works, I think it works using radiant energy from earth (Schumann Resonance) and then amplifying it. That is what I think, but you say about magnets? Here you have picture of TPU, I don't see magnets
The video that you have seen in youtube uses other system to create energy. Of course, you could build a better one device using more coils instead of one and make a self-running system. But I repeat, TPU extracts energy from the Earth Resonance, or maybe the coil is made with an special alloy like the Rod Generator (http://peswiki.com/index.php/Directory:Elemental_Rod_Generator), but Im almost sure the TPU system doesn't have moving parts. It's a motionless generator.
Magnets are a thing that we know only a very little part, if we want to know more about them we must to read at Howard Johnson, Edward Leedskalnin and more authors. Floyd Sweet, changed the configuration of the magnets, because with a common magnet you can't do all. If Steven Mark claims 6000 cycles per second I think he is saying about the resonance, not about a moving magnet.
Here you have a video of resonance dancing magnets
http://video.google.es/videoplay?docid=5540717206741162529&q=marcos+magnets
