Hydrogen Or Heat From Rotating Magnet
Started by wizkycho, August 18, 2008, 05:59:51 AM
wizkycho
Hi All!
please don't skip this turbo simple and possibly ultra quick way to Free Energy !
idea just pop-up
eddy currents heater breaker are known fact
http://physics.kenyon.edu/EarlyApparatus/Electricity/Foucaults_Disk/Foucaults_Disk.html
(high currents are induced in spinning metal disc) - heat is produced but allso breaking tht we don't want
1. So the idea is to change medium and use spinning water (instead of metal disc) or spinning magnets in proximity of water
- electrical currents induced in water will generate hydrogen ?
- electrical currents induced in water will generate heat ?
- breaking effect is allmost close to none, is it ?
- will generated heat and hydrogen overcome only friction energy nedded to rotate magnets ?
2. again instead of metal disc we use water in disc shaped container and make Homopolar Generator setup.
(Homopolar Generator is known to induce kiloAmps but at low voltage to use it for practical generator. kiloamps out - only friction in)
Imagine kiloAmps through Your electrolyzer !!!
again same four questions :
Please comment on this idea, has it been used, could it work ?
Can someone make quick experiment, I'm at work now and this whole week totaly occupied.
Wiz
wizkycho
is this too stupid idea ? (but it's damn easy to build experiment setup and usable working device)
does rotating magnets can even induce current in water as they would in metal ?
metal is conductive and water is - current should flow in both!
If in plain tap water can not be induced current lets add some or more Iron Powder in that water. If nothing powder will follow
magnets and make friction with water generating heat !
please some comments
wiz
dieter
kallstrom_74
i am looking forward to see if anyone can try this :)
