Thanks to ALL for your help!!
Help making a 2 transistor circuit to do what a SPDT swich does
Started by gotoluc, August 21, 2008, 05:22:25 PM
Groundloop
Wattsup,
If you set your voltage output to less than 15 volt peak to peak on the function generator and wire
the 4016 switches to do the job, then yes, you could probably control a P-channel and N-channel FET.
(I assume that 9540 is a P-Fet (IRF5Y9540CM) and that 840 is a N-Fet (IRF840), correct?)
Groundloop.
BEP
It looks complcated but it isn't when you start to breadboard the circuit....
http://www.4qdtec.com/h.html
This is the only true SS function of a DPDT switch. Same can be done with FETs. Expand the idea to be driven by another signal source like a 555 circuit. The common mistake is to do something that will allow the 'on' time of the top and bottom switch to overlap. This would be a short.
Cheers!
>>Edit
As usual. I'm in a hurry....
You said 'SPDT' not DPDT.  Only one half of this circuit is needed then and the posts by others are more correct for your question.
However, if you need to consider actually reversing applied voltage instead of flipping it between two loads consider the above.
I've never thought turning things on in a sequence was of any value. So I use something similar to the above to sequencially move or reverse a charge. This way all parts of the circuit are always doing something.
gotoluc
@Groundloop,
thanks for the extra time you put in to make the circuit simple enough for even me :P to understand. I will give this a try since I already have the 555 built. By the way I did chose a 1uf at ct but I got to get a 500k pot since my 100k does not give me enough Frequency range.
@c0mster,
thanks for the link to the 4016 device. Looks simple enough for me to understand. I think I'll get one of these for future tests as the logic is simple to understand and one could quickly put something together.
@wattsup,
thanks for looking and sharing that you also have a need for this. I like the simple idea of using a P-Fet and N-Fet like Groundloop is confirming below
Groundloop.
@BEP,
thank you also for sharing that circuit. Since I may also need reversing of applied voltage in future work.
Luc
