Emulsifying Brown's Gas
Started by goldenequity, August 24, 2008, 05:39:29 PM
goldenequity
Chris!
That's EXCELLENT man..... I'm so encouraged  ;D
Like I said.... this IS doable..... and LOTS of ways to skin this cat!!!!!!!!!!!!!!!!!!
Chris31
Yeah I think its the only way forward at the moment, that is mixing water/fuel.
I was originally exploding water using sparks using gotolucs circuit, after seeing my own results and reading others, Im more and more convinced that it is not possible to run the engine like that at the moment.
I remember pouring used veg oil from a take away and I see some water mixed with it. I use veg oil because I used to run my car on straight veg for about 2 years with no problem until the clutch went.
The only question is, if we mix 50/50, I wonder if the energy is also reduced to 50%? I hope not  :-\
goldenequity
Here is a possibility:
Most of us who have been studying this gas for awhile are struggling NOT with the power of HHO....
but how to SLOW down the burn rate so that it EXTENDS through the power stroke.
I think this is the way.... it's going to be a breakthrough as we develop this with plasma for ICE's.
I think it will be more powerful the more we trap the gas.... I can't wait!!!!!
goldenequity
BTW....
The patent claims that the liquid (water) is electrolyzed into HH and O as it passes through the magnetic field created within his magnetic/shear chamber.
That the mixer ITSELF electrolyses.
I can't help but believe that he figured out to introduce Brown's Gas along the way as he was emulsifying kerosene and water.
Either way the goal is the same...... trap them tiny bubbles!!!  ;D
Chris31
Quote from: goldenequity on August 28, 2008, 12:44:49 AM
BTW....
I have just done a quick one, use egg beater to mix water and veg oil. LOL
It works more or less the same as the fog machine, but mixing is much more rapid.
I think what we can do is have fuel and water tank. Then mix them on demand, this way the mixer can be just a small device driven by an electric motor. Some cars have electric fuel pump in the tank, but I dont think it will mix it good enough.
I cant test HHO water mix, I havent built a HHO machine yet.  :D
