Aliens are coming October 14th 2008 Galactic Federation
Started by shooter001, August 27, 2008, 01:21:01 PM
Drannom
Quote from: z.monkey on September 14, 2008, 08:31:07 AM
Howdy Drannom,
The Electrinium Battery is a interesting device.  A "permanent" battery.  Very intriguing process much like silicon semiconductor manufacturing but by adding silver and iron into the we get a superconductor instead of a semiconductor.  This is something that I would love to try.  You are growing crystals already, but if I am not mistaken you are using a cold process that is water based.  Have you ever considered growing silicon, or even silicon-iron-silver crystals?  This is a chemical process free energy battery.  I think that it is also similar to John Hutchison's Crystal Power Cell.  Do you know of anyone who is attempting this process?
Blessed Be...
hello Z_monkey
first, the Central Sun is not at the center of the universe, it is out of our universe, the creator has made some universes, so the Central Sun give the power to all the black holes, and black holes are usually at the center of a galaxy, some galaxies are melted and a black hole may not be always at the center of a galaxie
black hole receive energy from the Central Sun cause they are super big vortexes and may collect the Central Sun power from an hyperdimensional connection
so if a black hole is anywhere in the universe , it will not be less powerfull at all
second: electrinium is a way to convert Super Light from all the black holes (that we received) in electricity instead of only reflecting Super Light, in the electrinium there is also a simple recipe with steel, to convert Super Light in electricity you'll have to cristallize while putting a lot of voltage with low current, then the cristallized compound will get together two molecules with different density in a less space then it is suppose to be
that compression in the equilibrium of all matter, allow that cristallized compressed compound to emit more super light than other thing and transform it in electricity
all you need is two molecules like iron-silver or carbon-iron or many others possible combination of two molecules, i do not suggest to try iron silver at all, begin with more easy compound
there is many ways to collect Super Light, electrinium is one of them
most of all radiant devices, radiate Super Light, or a second consequence of the Super Light
It means that there is an equilibrium, break the equilibrium create electricity and fire, and magnets, and much more
i suggest to heat at red a layer of steel and apply a lot of volts on it while cristallizing the steel, each atomic layers will need is own voltage to get them together more near than normally possible
in Hutchinson topics they are not putting enough volts to get anything good !!!!!
each atomic layer of silver iron request 7 volts, so for one milimiter you'll need many thousand of volts !
in nanometer size of molecules it means a lot of layer just for 1 milimeter
secret governement use blue crystal to get full of power (from projectcamelot)
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
JRowe
I think, perhaps, that licensed counselors should be contacted and placed in touch with many of the people posting on this thread. Particularly the ones who agree with the premise of the OP. It is mindless idiocy like this that leads to so much of the horrendous tragedy and ignorance in the world.
P.S. Hi Drannom. I'm from the Secret Government. We're going to get you, Drannom. We have inverted pyramids and the Central Darkness, which are more powerful than your pyramids.
P.S. P.S. I also hack elevators.
Obviously sanity isn't a requirement for this forum... Is a healthy sense of humor allowed?
Yucca
I hope and dream that the giant ship will arrive and I don't mind if anyone thinks I'm crazy saying so,
Often times I lie outside and watch the stars, I often see satellites and shooting stars. Last night I saw a dim satellite that pulsed with a brilliant flash about once every 15 seconds. I saw it flash about 10 times. Yes maybe it was a slowly rotating satellite, but then maybe it wasn't.
In the past I've seen more dramatic UFOs; satellites with non ballistic trajectories, changing direction too fast for anything that's earthmade and documented.
I also once saw a military plane, pretty sure it was B2, in silent antigrav mode, flying very low and very slow (<=30kph) with absolutely NO noise. I was about 50m away sat up a tree on the edge of some woods when it passed me. The craft had white landing lights on, no visible nav lights, the cockpit was illuminated and I could see two men at the controls sat side by side wearing brown flight suites. And no, it wasn't a lorry coasting down a road or anything, there was no road, it was a soft soiled grass pasture, there were no tracks in the morning.
Drannom
Quote from: JRowe on September 15, 2008, 04:27:43 AM
Hi JRowe
i have a message for all the illuminatis followers, and the NWO followers
your boss, will let you down, they will go in underground basements and there will be no place for you, you'll stay on the earth surface and going to the 2012 event
i do not believe that your are such a followers cause all illuminatis will wonder of potassium alum pyramid
pyramid is the main symbol for them, and i cristallize pyramids growing in the exact shape of kheops, so if you get me you'll loose the expert in that
in fact i am the leader...
