Electrinium
Started by singerxyz, September 02, 2008, 05:41:20 AM
Drannom
Quote from: hypersoniq on September 28, 2008, 04:55:23 PM
@ Drannom... Whatif you were to layer what you need all in one "grow"? In such a manner that your constituent components (like flowing in the K Alum) could be switched midstream with a new substance...
I used to work with MOCVD reactors that grew laminated laser diodes on an indium substrate. THey would heat up the indium disc and flow different materials around it (cladding/active region[N/P regions]/cladding). The biggest concern was lattice matching (which they checked via X-ray).
I imagine it would take some research into the crystalline lattice matrices of each constituent component to get a close match at each phase without voids or the possibility of de-lamination,but it would be an interesting idea to just "grow" this whole thing in one operation and avoid any fusing/welding/torching operations completely...
is that possible? have you ever changed or added ingredients while making one of those pyramids?
well, i do not know, i will let you know if i brainstorms something on that, i can make alum growing between 2 plates, the distance between the 2 plates could be as less as half of a milimeter, and the crystal will spread between them from a little hole at the center on one of those plates
for your question, yess, anything that i can dissolve i will be able to coagulate it again in a cristallization process, so i imagine that i can dissolve in sulfuric acid some metals ?? may be, and then crystallize them together, if i dissolve 2 metals in acid then there will be one of those metal cristallizing before the other one
so, it will be only one metal solve in acid, then i shall try to crystallize this metal, the other metal will be not solvable in acid and this is a problem, and much more complicated to put 10 000 volts on the crystal while growing
i will not go to that way until i got a flash to solve those problems
@ Jeanna
QuoteThe other thought/question I have for you Drammon, is would you be able to devise a way to make silicon crystals using sodium silicate?
It is very thick so it would be harder than the water you use for alum.
i do not know
it will work if we can solve it in an acid or whatever, and it will work if it is transparent, cause i need to see what happen while the crystal is growing
in electrinium we have to put a lot of volts while growing the crystal, so i will not look to that way until i got another flash to solve those problems
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
nievesoliveras
Hi!
@all
Thank you for the counsel!
Jesus
Drannom
Quote from: nievesoliveras on September 28, 2008, 06:34:35 PM
Hi!
@all
Jesus
hey jesus, finally there is many electrinium compound ! with silicon or germanian, from silver-iron and iron with many others one
i have finish chap 9 and i have understand everythings up to now, i am excited to try understanding to the end
and Jesus i am very happy that you take the time to read it too, cause it is explan in the way that even a child can understand it, and my skill in english is approximatly that of a child like 9 years old
the electrinium compound become the electrinium unit, and that unit is cut to form electrinium battery
i will look for simple way, just get the electrinium unit, if there is too much volts then it will be not a problem to convert them in heat or whateverelse like some coils and swithching system to create ac electrinium unit
i look to the chap 10 see you
resonanceman
Quote from: Drannom on September 28, 2008, 05:59:01 PM
I also  doubt  of   high  voltage and high  current can  even be  done while the  crystal  forms .
If   you  have a metal  dissolved  in a fluid  and  apply  electricity,   you  are then electroplating.
The  current  needed for electroplating is MUCH less than we are talking about for aligning  the  molecules .
I  just had a thought .
maybe  a form of high voltage plating could be done by   adding just a very  small amount of  metal to the electrolyte.
gary
nievesoliveras
Hi!
@Drannon
Keep positive and you will do it!
Jesus
