Electrinium
Started by singerxyz, September 02, 2008, 05:41:20 AM
Drannom
Hello i have just finish chapter 10
i am sure that i will never try this method, i hope a team can do this in 6 months or more,
find borozon crystals to add to the iron-silver compound and then melt it with silicon, and grow a crystal, in a furnace !! big job
then reheating this crystal just to realign the iron-silver compound catch inside the crystal with high voltage and a resistance to protect the voltage device in input ! hope to not break the crystal then !!
i have understand perfectly chapter 10 ! thanks god !, and i will never suggest to try this here in this forum, i prefer to focus on many others simple way that is suppose to be as stated earlier in the electrinium.pdf
so here, there is 2 ways
those one with a lot of courage to try the borozon iron-silver silicon coumpound crystal, and try it for a very very longgggg time
and those one looking another way with steel and anything else like gold platinium, and the goal is to create a sort of aligment according to the electrinium theory
so , i will have to imagine the way to do it in the very easy way with the electrinium compound of iron-carbon and platinium
find and old battery of iron-silver will be usefull only for those trying the chapter 10 method
i think we all, have to find what is this very easy way what this means
Summera had explained that a piece of steel can be convert into a magnet with 3 big hit, and two magnets at both ends, i think to hit red hot steel with large spark while cooling will do the cristallisation and the polarization of the coumpound, cause the compound is the body, this is why it is simple, the simplest!!
i think to melt steel with platinium and try many possible ways to turn all the molecules in the right direction with high voltage
QuoteThe body of the Unit could bc made from a number of materials such as steel, Silicon,
Germanium, Carbon and others. Each of these materials would be suitable for an Electrinium Unit
designed for a particular purpose. Units made with steel bodies would be of an extreme voltage,
so high that they could not be cut and assembled into batteries, but they would be very easy to
m a ke. By using the steel as the nega t ive and Gold or Platinum as the positive, to make the
c o m p o u n d the compound becomes the body.
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
Drannom
hi resonanceman
you said
QuoteI am now thinking that adding  a  non  conductive powder might  be a good idea.    It would spread out the electrinium compound   and FORCE  the  current into  small streams
I just  got an image  about the  non  conductive  powder .
The  ratio  of   powder to  electriium  compound  would be important.
There would be several times more powder than electrinium .
The  channels  would  form  where  the current   would  find a low enough  path through the entire   junction.
Electrinium  particles  that  were not in  a low resistance path  would in effect be  wasted ...they would  be held out of the circuit  by the  powder
I am thinking that  higher  current  would   create more channels .
I am thinking that  the voltage  applied  and the ratio of non conductive powder to electinium compound  would  at least roughly  set the  final output  voltage..
Another  way to set the output voltage would be the  thickness of the junction
i think that is a simple way to try, it will be much easier than the chapter 10 method, keep going to channelled such good stuff, even from A. Summera himsefl !
there is a simple way, there is many simple way, even a simple way with the silver-iron compound
the simple way will be a very thin crystal, just to proove the concept
good night, my brain is ready to dream, about the electrinium
see you all, i will read the chapter 11
nievesoliveras
Hi!
I will vote for compound of iron-carbon and platinium. The easier way.
Jesus
resonanceman
Quote from: Drannom on September 28, 2008, 09:03:51 PM
Drannon
I think  you migh have something here ..
I never thought of hitting it to help line up the molecules  like they  do in magnets ........but if it works for magnets   it could work for this .....after all we are trying to make something that works  like a magnet .
I  also think that  a magnetic  field  like they use  for making magnets might be of help too .   .
the  temperature   would have to be right ....  to hot  and  the alignment  wouldn't hold .
I see no reason that  we couldn't  heat,  electric  currents,  magnetic fields, and  a few  sharp  thumps all at the same time if  we need to.
As far as melting the  steal and platinum  ......  I am wondering  if it is safer to make a battery and  then use the sludge .     It would be in the exact right  proportions  and  you  would  know for sure that  it was in electrinium pairs.    each molecule would  be  properly matched.        If the  2 metals  are just melted together  I am not so sure that they  will mix well enough that each molecule  will  be properly bonded to its pair.
Any one  have any  experience with how they would mix?
It would be  great if we could count on them mixing  well enough ....... ..simpler is better ......as long as simpler  works.
gary
resonanceman
Quote from: z.monkey on September 26, 2008, 03:55:05 PM
Howdy Y'all,
I just submitted the Electrinium Battery to Project 10100.
Project 10100 Thread
http://www.overunity.com/index.php/topic,5649.0/topicseen.html
Google is sponsoring this and they are putting up $10M for the best idea to improve the planet.  I figure that Electrinium is good for that and maybe we can get some research bucks off of it...
Blessed Be...
It would be great  if we could  get a proof of  concept  battery  made before the  deadline.
I think  it has a good chance WITH a working  battery even if the battery is very low power.
I don't think there is much chance of them  giving the money to  someone  with an energy  related idea without  proof that it  works
It wouldn't be a " safe " choice for them.
gary
