Electrinium
Started by singerxyz, September 02, 2008, 05:41:20 AM
nitinnun
remember that even the romans could melt glass, but dumping fuel into a simple brick oven.
until enough heat had "built up" in the oven, to melt even sand into glass.
bricks are VERY resistance to heat. especially if you have a thick enough wall of bricks.
i was thinking of a 2 foot long by 2 foot wide by 1 foot high oven. with a small opening inside, to hold the metals and sand.
and a hand held propane torch, dumping heat into the opening.
and a brick or 2 sealing up most of the opening, when the metals and sand are melting inside the oven.
if you moved quickly with thick metal tools, you could remove the brick lid, and remove the molten copper sand sand.
without your metal tools melting.
you would also have to be wearing a leather welding jacket, and a transparent welding mask. to protect your body from the intense heat., for the few seconds that your body is exposed to the heat.
if spear throwing, phalanx marching, providence conquering romans can do it, than so can we!
nitinnun
the iron atoms electrons, generate a magnetic field.
the copper atoms protons, generate a diamagnetic field.
.......in the ZPE molecule:
the irons magnetic field, disrupts the coppers protons?
and the coppers diamagnetic field, disrupts the irons electrons?
one atom is disrupting the other atom, as long as the ZPE molecule is whole?
the disrupted copper and the disrupted iron, share each others density/weight?
causing even more disruptance-generated-electricity?
and what did you mean about these disrupted atoms creating their own pressure?
nitinnun
or could i say that the coppers clockwise spin, is disrupting the irons electrons?
and the irons counter-clockwise spin, is disrupting the coppers protons?
does light from the sun, energize the protons?
causing them to spin clockwise?
and anti-light from a blackhole, energize electrons?
causing them to spin counter-clockwise?
nitinnun
.....i put 2 sticks of copper into an empty plastic glue bottle.
(there was some residual glue on the bottle)
i filled it most of the way with clean ground water.
(no chlorine or flouride-poison in this water!)
i hooked the 2 copper sticks up to a 9 volt battery. and left it that way for an hour or so.
i just checked it. and the water has turned a vived green color.
which tells me that lots of copper atoms have broken off into it.
i disconnected the 9 volt battery, and checked the multimeter.
this litte "monatomic copper vat", was holding voltage and amperage.
so i shorted out the 2 copper sticks for a few second, and checked again.
and the monatomiccopper vat, is recharging itself!
i think there might be a ZPE molecule-like reaction, between the copper atoms, carbon atoms, and the oxygen/hydrogen atoms in the water.
but i'm leaving the vat shorted out for awhile, to see how long it takes this living-dead recharge rate, to go away.
nitinnun
this is the atom allocation that i had in mind.
ironically, the electricity will not be able to travel through the glue, from one terminal to the other.
because the glues electrical resistance will be too high.
it will be the magentism that draws the metal atoms towards the terminals.
only the magnetism of the "charge-up electricity" will travel through the glue, from one terminal to the other.
