Electrinium
Started by singerxyz, September 02, 2008, 05:41:20 AM
Drannom
Quote from: nievesoliveras on October 23, 2008, 10:42:10 AM
Hi!
@drannom
Dont get me wrong, I am just trying to help and solve the electrinium problem.
Jesus
no problem, i will not talk about that, you can, and everyone can
if you want to talk about electrinium ! wowwwww super !!!  ok
i am ready.......
in the electrinium we are about to find the atomic volume of all atoms, then we will find some difference in the total electrical charge
electrical charge = weight x volume
density = volume divide by weight
so i was not wrong talking about density
so, we are looking the way to get the compound, and to find an easy way we have to find the density of each atoms, and then match them with that difference
Summera give us many combination possible, the less expensive seem to be the silver-iron compound
then we will align it and compress it with high voltage in any hardener or crystal process
and, to get the silver-iron compound
as you know
we have to CREATE a normal silver-iron battery, with NaCN
so, Nitinnun propose to use iron-copper, good
let's try it, all i need is the receepe to create the iron-copper compound
and i have not understand it pretty well, in the Nitinnun's theory the iron and copper atoms are free, in the electrinium it has to be create
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
nievesoliveras
Hi!
@drannom
I am a visual person, meaning that for me to understand something I need to have a graphic or somethig to visualize the idea.
When you used graphics to explain the great job you did with growing pyramid crystals. I understood quickly the process you were trying to explain. When you use a graphic and just a little words, the graphic itself talks for you and is understood. I am based on the saying that a picture has the value of a thousand words.
Remember, I can be wrong though.
Jesus
nitinnun
i put copper, steel, lead, bismuth, and aluminum into a contaner with glue.
but there is VERY LITTLE room between all of them. so i am slowly putting in thin layers of glue, and drying them.
to lock the metals in place, before i touch any of them.
in a few days, i'll be able to test the 5-metal beatdown!
though it will take tinkering to see which metals work best on which terminal.
nitinnun
THIS was taken from an old tesla patent.
i think that it works EXTREMELY SIMILAR, to my cells, and to electrinium.
heat excites the iron. increasign its paramagnetism.
(ferromagnetism is just a stronger version of paramagnetism. the different name, is to confuse us!)
the increased PARAMAGNETISM of the iron, attracts clockwise spin generated by the air.
the sheet catches this clockwise spin. charging up the positive half of the battery.
the diamagnetic spin, attracts coutner-cklockwise spin generated by the ground.
this CCW travels up into the metal and up into the negative half of the battery.
because the CCW wants to climb as high as possible, towards the diamagnetic sky.
the CCW in the hot iron, attracts even more CW from the sky.
it works EXACTLY like how i tried to make the pyramid work.
the only differences are that i didn't excite any iron like that, i didn't have anything over iron to catch CCW, and i didn't purposely connect 2 metals to the negative battery terminal.
nievesoliveras
Hi!
@nitinnun
You and drannom are the most active members of this thread!!
Jesus
