Electrinium
Started by singerxyz, September 02, 2008, 05:41:20 AM
z.monkey
Howdy Y'all,
Broli, there is a current flow through from the emitter to the collector through the resistive conductor.  The current flow generates a magnetic field not an electric field.  Electrinium is a permanent battery or current source.  A capacitor is a temporary current storage tank, while the Electrinium is rectifying Super Light and converting it to electric current in the same way a permanent magnet converts Super Light into magnetic current (magnetic flux).
Resonanceman, yes, without the Central Sun there would be no life here.  According to Mr. Summera the energy from the Central Sun 'inflates" and energizes all matter in the entire galaxy.  I have been conversing with Drannom about this for a long time.  You can read back through my posts to find information on Super Light.  The Central Sun provides Super Light which energizes all matter within the galaxy.  Super Light is "dark" energy, which means it is above our perceptual spectrum.  It is the reason for magnetism and electricity, as well as life.  Our Solar Sun converts Super Light in to light, heat, gravity, and electromagnetic radiation.  The elemental mass of the Earth also converts Super Light into other usable energetic phenomena, including gravity.  The Electrinium battery is rectifying Super Light into electric current.  The source of Super Light is infinite so this is why an Electrinium battery can be a permanent battery.  It is not violating the laws of physics, just utilizing information that was not known before.  The Electrinium battery rectifies Super Light into electric current in the same way that a permanent magnet rectifies Super Light into magnetic flux. Whether the source of this information is aliens or divine revelation is irrelevant it is supremely profound nonetheless.  Whoever Mr. Summera really is may never be known.  This document was published pseudo anonymously because, as WizardofMars pointed out, the address on the document is not real, and Aurthur Summera is a ghost or a pen name.  But this information resonates within my soul.  I can see the mechanics of the theories working in my mind as I read the document.  It makes perfect sense.  Also when you understand the theories of the Central Sun and Super Light this is real technology which already exists, yet not in this form yet...
Blessed Be...
Goodwill to All, for All is One!
Drannom
in fact i have talked about super light in 5 topics, just look at all my posts to find all my views on that
for example : all black holes are votexes, and the Central Sun give power to them no matter the distance from the center of the universe, cause the Central Sun is not at the center of the universe and give power to all black holes hyperdimensionnally from the celestial plan
for example all electricity is an unbalance in the eather, if you charge a serie of caps and put current at both ends, all the caps in the middle will charge up as well !, so electricity is much more like an eatheric pressure than electrons
is see that in a simple picture where all universes are only vibrating eather receiving constantly the Super Light through their black holes
it means that there is a super super light over the super light, and that super super light is from the Central Sun
and black holes convert the super super light in super light, and our solar sun convert the super light in normal light
breaking the equilibrium in the eather will create a flow of electricity, electrinium device is continually breaking equilibrium by a compressed zone with two atoms or two molecules harmonically tune to convert super light in electricity
Master in alum pyramid growing crystals at http://youtube.com/user/Cristallerie
As intriguing as the theory sounds. I'm still trying to understand the basic principle. Z, I don't really get what you said since you seemed to have just slapped "Super Light".in there. But if you have charged particles lined up like that, but not allow them to exchange any electrons....then where is the flow of electrons coming from.
z.monkey
Howdy Y'all,
Thanks for the explanation Drannom.
Broli, do you understand diode junctions?  You can look at the Electrinium molecules like diode junctions.  The polarity of the molecule allows a voltage across the molecule and the electrons (or ether pressure) is being forced in one direction only.  According to the Electrinium document this voltage is 7 Volts across 1 molecule.  So you can see when you line up a bunch of these molecule the voltages increase fast.  The trade off for the high voltage is current, so there is a relatively feeble current.  This is the reason that we have to parallel the Electrinium crystals to get appreciable power.
The current that is being produced within the Electrinium Battery is supplied by Super Light.  If our Electrinium Battery is represented as a string of diode junctions then it can be viewed as a radio receiver of sorts.  The Central Sun is "transmitting" Super Light and the Electrinium Battery is the "receiver"  where the Super Light is "received" rectified and converted into electric current.  You will need to review the theory of the Central Sun and Super Light.  This theory is covered in the Electrinium.pdf document in the first post of this thread.  Also look at this link...
http://blog.hasslberger.com/2007/11/milewski_describes_magnetoelec.html
Maybe this can help you to get a handle on Super Light...
Blessed Be...
nievesoliveras
Hi!
We are trying to make an electrinium battery. To get the electrinium battery, we need to form some cristals. There is this process that may be useful to understand the crystals we need. May be we can grow the crystals instead of getting them with a metal fusion.
Kayex Silicon Crystal Growing Process
http://www.kayex.com/silicon-crystal-growing.asp
Jesus
